A function-definition is not allowed here before '{' token problem
Hey, I am currently programming a macro pad with 5 buttons and a rotary encoder. The encoder should be able to change the volume up and down, as well as play/pause on click and next track when held. I am pretty new to coding so I'm a bit confused by the error. I am also using an Arduino Pro Micro
Here is my code, and the error is at the end:
#include <HID-Project.h>
#include <HID-Settings.h>
#include <Encoder.h>
#include <Bounce2.h>
// Rotary Encoder Inputs
#define inputCLK 16
#define inputDT 14
#define inputSW 15
int currentStateCLK;
int previousStateCLK;
  //Encoder
int SW = 15;
int DT = 14;
int CLK = 16;
//Set up the button grid
const int numButtons = 6;
const int buttonPins[numButtons] = {9,8,7,6,5,15}; //defining the pins in an order from right to left
int state = 0; //Set the current state
//Set up all the buttons as bounce objects
Bounce buttons[] = {Bounce(buttonPins[0],10),Bounce(buttonPins[1],10),Bounce(buttonPins[2],10),Bounce(buttonPins[3],10),Bounce(buttonPins[4],10),Bounce(buttonPins[5],10)};
  // Set encoder pins as inputs
  pinMode (inputCLK,INPUT);
  pinMode (inputDT,INPUT);
  pinMode(inputSW, INPUT_PULLUP);
  // Setup Serial Monitor
  Serial.begin (9600);
  Consumer.begin();
  Keyboard.begin();
  // Read the initial state of inputCLK
  // Assign to previousStateCLK variable
  previousStateCLK = digitalRead(inputCLK);
  Keyboard.begin(); //Start the Keyboard object
for(int i = 0; i < numButtons; i++){
    pinMode(buttonPins[i], INPUT_PULLUP);
   //check all buttons
  for(int j = 0; j < numButtons; j++){
    if(buttons[j].update()){
      if(buttons[j].fallingEdge()){
        //Serial.write("Button");
 //use the current state and the button number to find the command needed and send it.
   switch (state) {
   case 0: //Layout 1
   switch (j) {
case 0: //F6
               Keyboard.press(KEY_F1);
               delay(100);
                Keyboard.releaseAll();
case 1: //
               Keyboard.press(KEY_F2);
               delay(100);
case 2: //
               Keyboard.press(KEY_F3);
               delay(100);
case 3: //
                Keyboard.press(KEY_F4);
                delay(100);
case 4: //
                Keyboard.press(KEY_F5);
                delay(100);
case 5: //
                Keyboard.press(KEY_ESC);
                delay(100);
//check the encoder button
  if(encoderButton.update()) {
    if(encoderButton.fallingEdge()) {
      int fall = millis();
      while(!encoderButton.update()){}
      if(encoderButton.risingEdge()){
        int rise = millis();
        //Serial.println(rise - fall);
        if(rise - fall > timeLimit){
          Consumer.write(MEDIA_NEXT);
          Serial.print("Next");
          Consumer.write(MEDIA_PLAY_PAUSE);
          Serial.print("Play/Pause");
  // Read the current state of inputCLK
  currentStateCLK = digitalRead(inputCLK);
  // If the previous and the current state of the inputCLK are different then a pulse has occured
  if (currentStateCLK != previousStateCLK){
    // If the inputDT state is different than the inputCLK state then
    // the encoder is rotating counterclockwise
    if (digitalRead(inputDT) != currentStateCLK) {
      rotateRight();
      rotateLeft();
  // Update previousStateCLK with the current state
  previousStateCLK = currentStateCLK;
void rotateRight() {
  // Increase the volume.
  Consumer.write(MEDIA_VOLUME_UP);
void rotateLeft() {
  // Decrease the volume.
  Consumer.write(MEDIA_VOLUME_DOWN);
The error message showing up when I try verifying:
Arduino: 1.8.13 (Windows 10), Board: "SparkFun Pro Micro, ATmega32U4 (5V, 16 MHz)"
In file included from c:\users\190240\documents\arduino\libraries\hid-project\src\hid-apis\KeyboardAPI.h:29:0,
                 from c:\users\190240\documents\arduino\libraries\hid-project\src\hid-apis\defaultkeyboardapi.h:27,
                 from C:\Users\190240\Documents\Arduino\libraries\HID-Project\src/SingleReport/BootKeyboard.h:30,
                 from C:\Users\190240\Documents\Arduino\libraries\HID-Project\src/HID-Project.h:50,
                 from C:\Users\190240\Desktop\Electronic Tech Macropad\Test_Code_1\Test_Code_1.ino:1:
c:\users\190240\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:54:21: note: #pragma message: Using default ASCII layout for keyboard modules
     #pragma message "Using default ASCII layout for keyboard modules"
C:\Users\190240\Desktop\Electronic Tech Macropad\Test_Code_1\Test_Code_1.ino: In function 'void setup()':
Test_Code_1:48:13: error: a function-definition is not allowed here before '{' token
Test_Code_1:143:1: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
Any help would be appreciated!
Your curly brackets are mismatched. The IDE autoformat tool (ctrl-t or Tools, Auto Format) will help you to see where the mismatch(es) occur.
The first that I see is a missing } to close the setup() function.
And the loop() function is not properly closed before the function definitions for rotateRight() and rotateLeft().
So I did that and it fixed that error, however I then got another error about some things being not declared in this scope.
This is the error message:
C:\Users\190240\Desktop\Electronic Tech Macropad\Test_Code_1\Test_Code_1.ino: In function 'void loop()':
Test_Code_1:96:15: error: 'encoderButton' was not declared in this scope
           if (encoderButton.update()) {
Test_Code_1:103:35: error: 'timeLimit' was not declared in this scope
                 if (rise - fall > timeLimit) {
Test_Code_1:123:15: error: 'rotateRight' was not declared in this scope
               rotateRight();
Test_Code_1:125:15: error: 'rotateLeft' was not declared in this scope
               rotateLeft();
Test_Code_1:132:28: error: a function-definition is not allowed here before '{' token
Test_Code_1:137:27: error: a function-definition is not allowed here before '{' token
         void rotateLeft() {
exit status 1
I'm not sure what this means and how to fix it
Whenever you make changes to your code, post the latest version so we can keep up.
Here is the latest version:
#define inputCLK 16
#define inputDT 14
#define inputSW 15
//Encoder
int SW = 15;
int DT = 14;
int CLK = 16;
const int buttonPins[numButtons] = {9, 8, 7, 6, 5, 15}; //defining the pins in an order from right to left
Bounce buttons[] = {Bounce(buttonPins[0], 10), Bounce(buttonPins[1], 10), Bounce(buttonPins[2], 10), Bounce(buttonPins[3], 10), Bounce(buttonPins[4], 10), Bounce(buttonPins[5], 10)};
  pinMode (inputCLK, INPUT);
  pinMode (inputDT, INPUT);
  Consumer.begin();
  Keyboard.begin();
  for (int i = 0; i < numButtons; i++) {
    //check all buttons
    for (int j = 0; j < numButtons; j++) {
      if (buttons[j].update()) {
        if (buttons[j].fallingEdge()) {
          switch (state) {
            case 0: //Layout 1
              switch (j) {
                case 0: //F6
                  delay(100);
                case 1: //
                  delay(100);
                case 2: //
                  delay(100);
                case 3: //
                  delay(100);
                case 4: //
                  delay(100);
                case 5: //
                  delay(100);
            if (encoderButton.fallingEdge()) {
              while (!encoderButton.update()) {}
              if (encoderButton.risingEdge()) {
          if (currentStateCLK != previousStateCLK) {
              rotateRight();
              rotateLeft();
        void rotateLeft() {
I fixed the setup() function by adding a {, but I am unsure what you mean in the second part about rotateRight and rotateLeft.
I verified after fixing the first problem and this is the error message:
                 from C:\Users\190240\Desktop\sketch_jun09a\sketch_jun09a.ino:1:
C:\Users\190240\Desktop\sketch_jun09a\sketch_jun09a.ino: In function 'void loop()':
sketch_jun09a:97:15: error: 'encoderButton' was not declared in this scope
sketch_jun09a:104:35: error: 'timeLimit' was not declared in this scope
sketch_jun09a:124:15: error: 'rotateRight' was not declared in this scope
               rotateRight();
sketch_jun09a:126:15: error: 'rotateLeft' was not declared in this scope
               rotateLeft();
sketch_jun09a:133:28: error: a function-definition is not allowed here before '{' token
sketch_jun09a:138:27: error: a function-definition is not allowed here before '{' token
         void rotateLeft() {
exit status 1
Hello
did you clean up the bracket salat within your sketch?
I'm sorry I have no idea what your talking about I'm new to coding. Could you please explain a bit better for me.
see post #2
If you mean using auto format, I did do it but here is the code after that anyways
#define inputCLK 16
#define inputDT 14
#define inputSW 15
//Encoder
int SW = 15;
int DT = 14;
int CLK = 16;
  Consumer.begin();
  Keyboard.begin();
  //check all buttons
        switch (state) {
          case 0: //Layout 1
            switch (j) {
              case 0: //F6
                delay(100);
              case 1: //
                delay(100);
              case 2: //
                delay(100);
              case 3: //
                delay(100);
              case 4: //
                delay(100);
              case 5: //
                delay(100);
            rotateRight();
            rotateLeft();
      void rotateLeft() {
read again:
in other words:
You can't declare functions like rotateRight() or rotateLeft() within loop.
Put them OUTSIDE of loop.
These functions have to be on the same level like setup() or loop().
After your changes press again CTRL-T and see if the functions align correctly.
Then try again to compile.
That makes more sense thanks for clearing it up. I think I did it correctly, I'll put my new code here to see if its right.
#define inputCLK 16
#define inputDT 14
#define inputSW 15
//Encoder
int SW = 15;
int DT = 14;
int CLK = 16;
void rotateLeft() {
  Consumer.begin();
  Keyboard.begin();
  //check all buttons
        switch (state) {
          case 0: //Layout 1
            switch (j) {
              case 0: //F6
                delay(100);
              case 1: //
                delay(100);
              case 2: //
                delay(100);
              case 3: //
                delay(100);
              case 4: //
                delay(100);
              case 5: //
                delay(100);
            rotateRight();
            rotateLeft();
Also, after compiling I get another error that has to do with encoder button;
sketch_jun09a:107:13: error: 'encoderButton' was not declared in this scope
sketch_jun09a:114:33: error: 'timeLimit' was not declared in this scope
exit status 1
just continue reading with the error messages:
I suspect you missed to initialize an encoderButton object.
See the examples of your libraries how to do that.
Thank you so much for the help. I found some code that I left out and when I out it in it worked.
