This sketch was compiling well.
Error came when works as a Tab and modified just a little as noted. why?
a function-definition is not allowed here before '{' token
ERROR:
Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_905466 -warnings=none -build-cache C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_cache_981239 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\00_MAIN\MEGA2560.MAIN_test\MEGA2560.MAIN_test.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_905466 -warnings=none -build-cache C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_cache_981239 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\00_MAIN\MEGA2560.MAIN_test\MEGA2560.MAIN_test.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_905466\\sketch\\MEGA2560.MAIN_test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for LiquidCrystal.h: [LiquidCrystal-1.0.7@1.0.7]
ResolveLibrary(LiquidCrystal.h)
-> candidates: [LiquidCrystal-1.0.7@1.0.7]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_905466\\sketch\\MEGA2560.MAIN_test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src" "C:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src\\LiquidCrystal.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_905466\\sketch\\MEGA2560.MAIN_test.ino.cpp" -o "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_905466\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_905466\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_905466\\sketch\\MEGA2560.MAIN_test.ino.cpp" -o "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_905466\\sketch\\MEGA2560.MAIN_test.ino.cpp.o"
E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\00_MAIN\MEGA2560.MAIN_test\MEGA2560.MAIN_test.ino: In function 'void setup()':
MEGA2560.MAIN_test:72:13: error: a function-definition is not allowed here before '{' token
ACDC:32:1: error: a function-definition is not allowed here before '{' token
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:30:0,
from C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_905466\sketch\MEGA2560.MAIN_test.ino.cpp:1:
ACDC:55:1: error: expected unqualified-id before string constant
ISR (ANALOG_COMP_vect)
ACDC:56:1: error: a function-definition is not allowed here before '{' token
ACDC:69:1: error: a function-definition is not allowed here before '{' token
ACDC:164:28: error: a function-definition is not allowed here before '{' token
void ACDCch_select(byte n) { // added "ACDC"
ACDC:191:1: error: expected '}' at end of input
Using library LiquidCrystal-1.0.7 at version 1.0.7 in folder: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\LiquidCrystal-1.0.7
exit status 1
