Hello there, I'm new to Arduino IDE. I tried to coding to ESP8266 and this error always prompted. Pls help, I have no idea how to fix this.
Here's the code.
#include <ESP8266WiFi.h>
#include <ThingSpeak.h>
#include <SoftwareSerial.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
String apiKey = "FQUT56BIHJV0A4QU";
const char* ssid = "เปโรโระ";
const char* password = "12345678";
const char* server = "api.thingspeak.com/update?api_key=FQUT56BIHJV0A4QU&field1=0";
struct MyVariable
byte nitrogen;
byte phosphorus;
byte potassium;
MyVariable variable;
WiFiClient client;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define RE 2
#define DE 0
//const byte code[]= {0x01, 0x03, 0x00, 0x1e, 0x00, 0x03, 0x65, 0xCD};
const byte nitrogen[] = {0x01,0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
const byte phosphorus[] = {0x01,0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte potassium[] = {0x01,0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
byte values[11];
SoftwareSerial mod(14,12);
mod.begin(4800);
pinMode(RE, OUTPUT);
pinMode(DE, OUTPUT);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi Connected");
Serial.print("Wi-Fi connected.");
Serial.print("IP Address : ");
Serial.println(WiFi.localIP()); // ทำการ Print IP ที่ได้รับมา
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //initialize with the I2C addr 0x3C (128x64)
display.clearDisplay();
display.setCursor(30, 5);
display.setTextSize(1);
display.setTextColor(WHITE);
display.println(" NPK Sensor");
display.setCursor(30, 20);
display.print("Initializing");
display.setCursor(35,40);
display.print("IP Address \n");
display.setCursor(20,50);
display.println(WiFi.localIP());
display.display();
delay(3000);
void loop () {
byte nitrogen();
delay(250);
byte phosphorus();
delay(250);
byte potassium();
delay(250);
Serial.printf("Connection Status: %d\n", WiFi.status());// แสดงสถานะการเชื่อมต่อ
delay(2000);
Serial.print("Nitrogen: ");
Serial.print(variable.nitrogen);
Serial.println(" mg/kg");
Serial.print("Phosphorous: ");
Serial.print(variable.phosphorus);
Serial.print("Potassium: ");
Serial.print(variable.potassium);
delay(2000);
display.setCursor(0, 5);
display.print("IP Address : \n");
display.setCursor(0, 15);
display.setCursor(0, 25);
display.print("N: ");
display.print(variable.nitrogen);
display.print(" mg/kg");
display.setCursor(0, 35);
display.print("P: ");
display.print(variable.phosphorus);
display.setCursor(0, 45);
display.print("K: ");
display.print(variable.potassium);
display.display();
byte nitrogen(){
digitalWrite(DE,HIGH);
digitalWrite(RE,HIGH);
delay(10);
if(mod.write(nitro,sizeof(nitro))==8){
digitalWrite(DE,LOW);
digitalWrite(RE,LOW);
for(byte i=0;i<7;i++){
//Serial.print(mod.read(),HEX);
values[i] = mod.read();
//Serial.print(values[i],HEX);
//Serial.println();
return values[4];
byte phosphorous(){
delay(10);
if(mod.write(phos,sizeof(phos))==8){
return values[4];
byte potassium(){
delay(10);
if(mod.write(pota,sizeof(pota))==8){
return values[4];
if (client.connect(server, 80))
if (client.connect(server, 80)) {
String postStr = apiKey;
postStr += "&field1=";
postStr += String(variable.nitrogen);
postStr += "&field2=";
postStr += String(variable.phosphorus);
postStr += "&field3=";
postStr += String(variable.potassium);
postStr += "r\n\r\n\r\n";
client.print ("POST/update HTTP/1.1\n");
client.print ("Host: api.thingspeak.com/update?api_key=FQUT56BIHJV0A4QU&field1=0\n");
client.print ("Connection: close\n");
client.print ("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.print ("Content-Type: application/x-www-form-urlencoded\n");
client.print ("Content-Length: ");
client.print (postStr.length());
client.print ("\n\n");
client.print (postStr);
Serial.println ("Data Sent to Server");
client.stop();
Errors :
C:\Users\p6052\OneDrive\Documents\Arduino\DataCom_Test\DataCom_Test.ino: In function 'void loop()':
C:\Users\p6052\OneDrive\Documents\Arduino\DataCom_Test\DataCom_Test.ino:135:18: error: a function-definition is not allowed here before '{' token
135 | byte nitrogen(){
C:\Users\p6052\OneDrive\Documents\Arduino\DataCom_Test\DataCom_Test.ino:152:21: error: a function-definition is not allowed here before '{' token
152 | byte phosphorous(){
C:\Users\p6052\OneDrive\Documents\Arduino\DataCom_Test\DataCom_Test.ino:169:19: error: a function-definition is not allowed here before '{' token
169 | byte potassium(){
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: C:\Users\p6052\OneDrive\Documents\Arduino\libraries\Adafruit_SSD1306
Not used: C:\Users\p6052\OneDrive\Documents\Arduino\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
exit status 1
Compilation error: a function-definition is not allowed here before '{' token
