a function-definition is not allowed here before '{' token
I Get This message a function-definition is not allowed here before '{' token, when I Try to compile;
Here is my code.
DigitalReadSerial
Reads a digital input on pin 2, prints the result to the serial monitor
This example code is in the public domain.
// digital pin 2 has a pushbutton attached to it. Give it a name:
int pushButton = 2;
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// make the pushbutton's pin an input:
pinMode(pushButton, INPUT);
int buttoncount =(0 ,4);
int step1;{
int step2;
// the loop routine runs over and over again forever:
void loop (){
// read the input pin:
int buttonState = (buttonstate + digitalRead(pushButton));
// print out the state of the button:
if (buttonState = 1)goto step1;{
else buttonState=0 goto step2;{
Serial.println(buttoncount);
delay(1); // delay in between reads for stability
step1:
int buttoncount=(buttoncount +1);
delay , 1000
return
step2:
return
First, use the "</>" button to encapsulate your SKETCH when posting code on this forum.
Next, try matching up all of the "Open and Close Curly Braces"
Does this line of code make sense?
