a function-definition is not allowed here before '{' token
Hello please help me :)
int pin = 1; void setup() {
} void loop() { float temp = (temp - .5) * 100; Serial.println(temp); delay(1); float getvoltage(int pin){ return(analogRead(pin) * .004882814); } }
ERROR:C:\Users\User\AppData\Local\Temp\arduino_modified_sketch_450312\sketch_may31a.ino: In function 'void loop()':
sketch_may31a:13: error: a function-definition is not allowed here before '{' token
exit status 1 a function-definition is not allowed here before '{' token
You have the 'getvoltage(int pin)' function inside of loop(). It should be outside, typically below, and in alphabetical order with other future functions.
Thank you :slight_smile:
