a function-definition is not allowed here before '{' token
I'm trying to control blinds with a ESP8266 and Alexa.
I generated device ID’s with Sinric.com
When I create the loop I get Following error:
exit status 1
This Is the part of the code that gives error: ( :frowning: Error cursor at this location when uploading)
webSocket.loop();
if(isConnected) {
uint64_t now = millis();
if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
heartbeatTimestamp = now;
webSocket.sendTXT("H");
:frowning: void turnOn(String deviceId) {
if (deviceId == "5cf8de1d0837cc3a87c8faf5") // Device ID of first device
Serial.print("Turn on device id: ");
Serial.println(deviceId);
digitalWrite(relayPin, HIGH); // turn on relay with voltage HIGH
else {
Serial.print("Turn on for unknown device id: ");
void turnOff(String deviceId) {
if (deviceId == "5cf8de4d0837cc3a87c8faf7") // Device ID of first device
Serial.print("Turn off Device ID: ");
digitalWrite(relayPin, LOW); // turn off relay with voltage LOW
else {
Serial.print("Turn off for unknown device id: ");
You need to complete loop() before you start any other function definitions. If you use Ctrl-T (Tools/Auto Format ) in the IDE you'll see what's wrong. Braces {} must always pair up.
Steve
540/5000
I have adjusted the code and now it works without error. see the code at the bottom
but now I need this piece of code that must be repeated every time:
// Change direction when the stepper reaches the target position
if (stepper1.distanceToGo () == 0) {
stepper1.moveTo (-stepper1.currentPosition ());
stepper1.run ();
inserted below: void turnOn (String deviceId) {
when I insert it, the code is only runs once, that's why I thought it should be in the loop.
Do you have a solution?
webSocket.loop();
if (isConnected) {
if ((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
else {
else {
