a function definition is not allowed here error
I am currently trying to combine a mazerunner code with a super mario brothers code and am running into a bit of problems. My most recent error message is:
Arduino: 1.8.10 (Mac OS X), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
/Users/brandonbruetsch/Documents/Arduino/arduino/arduino.ino: In function 'void setup()':
arduino:307:1: error: a function-definition is not allowed here before '{' token
arduino:315:18: error: a function-definition is not allowed here before '{' token
void sing(int s) {
arduino:365:55: error: a function-definition is not allowed here before '{' token
void buzz(int targetPin, long frequency, long length) {
Multiple libraries were found for "Wire.h"
Used: /private/var/folders/92/25d5dpdx3_93pj_vn5g_x3m40000gn/T/AppTranslocation/FA4D8BC0-D5A5-4256-885E-C4B40D934A2C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire
Multiple libraries were found for "Adafruit_GFX.h"
Used: /Users/brandonbruetsch/Documents/Arduino/libraries/Adafruit-GFX-Library
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: /Users/brandonbruetsch/Documents/Arduino/libraries/Adafruit_SSD1306
Multiple libraries were found for "SPI.h"
Used: /private/var/folders/92/25d5dpdx3_93pj_vn5g_x3m40000gn/T/AppTranslocation/FA4D8BC0-D5A5-4256-885E-C4B40D934A2C/d/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
exit status 1
option enabled in File -> Preferences.
My Code is here:
Serial.println(" 'Mario Theme'");
    int size = sizeof(melody) / sizeof(int);
    for (int thisNote = 0; thisNote < size; thisNote++) {
      // to calculate the note duration, take one second
      // divided by the note type.
      //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
      int noteDuration = 1000 / tempo[thisNote];
      buzz(melodyPin, melody[thisNote], noteDuration);
      // to distinguish the notes, set a minimum time between them.
      // the note's duration + 30% seems to work well:
      int pauseBetweenNotes = noteDuration * 1.30;
      delay(pauseBetweenNotes);
      // stop the tone playing:
      buzz(melodyPin, 0, noteDuration);
  digitalWrite(13, HIGH);
  long delayValue = 1000000 / frequency / 2; // calculate the delay value between transitions
  //// 1 second's worth of microseconds, divided by the frequency, then split in half since
  //// there are two phases to each cycle
  long numCycles = frequency * length / 1000; // calculate the number of cycles for proper timing
  //// multiply frequency, which is really cycles per second, by the number of seconds to
  //// get the total number of cycles to produce
  for (long i = 0; i < numCycles; i++) { // for the calculated length of time...
    digitalWrite(targetPin, HIGH); // write the buzzer pin high to push out the diaphram
    delayMicroseconds(delayValue); // wait for the calculated delay value
    digitalWrite(targetPin, LOW); // write the buzzer pin low to pull back the diaphram
    delayMicroseconds(delayValue); // wait again or the calculated delay value
  digitalWrite(13, LOW);
That is not a complete sketch.
That error indicates that there is a function definition inside the definition of setup() - functions inside a function are not valid C. Likely the cause of the problem is that you missed a closing }.
Ctrl+T will indent everything so the indentation matches the number of brackets deep a line is. This usually makes problems of this sort trivial to locate and fix.
