A function to write several digital outputs at once (C++ level)
Please, find below a function that can be useful to output a set of digital values "at the same time".
Instead of doing a set of digitalWrites, you could use this function and one array with multiple values.
void emitPins(int val2emit, int pinIni, int pinFinal)
  int nPins = pinFinal - pinIni + 1;
  int pin2emit = pinIni;
  for(int i=0; i <nPins; i++){
	if(bitRead(val2emit, i) == 1)
		digitalWrite(pin2emit, HIGH);
		digitalWrite(pin2emit, LOW);
	pin2emit ++;
For example, you can employ it to light a set of patterns on 8 LEDs connected to digital pins 2 to 9, using a loop.
int LEDS[8] = {1,2,4,8,16,32,64, 128};
for(int i=0; i<8;i++){
       emitPins(LEDS[i], 2,9);
I am just sharing a function that could be useful for the community.
I have no doubts or questions regarding this code. Just sharing.
Thanks.
Do you have a question?
Code tags?
Formatting?
Thanks TMFKA-AWOL. It was just an (incomplete) suggestion.
A suggestion for what?
A suggestion for ignoring the contents of an array?
Code tags?
Formatting?
It was incomplete at the time you answered. I hope it is more complete and understandable now.
Thanks.
It is not complete without code tags.
Hello
This is a sketch on beginer level.
Done, thanks
I think the code would be better if it allowed non-sequential output pins.
All it would take would be another array.
That would be another variant, in which you could use a second array for the non-sequential pins.
The code below compiles OK, but is not checked on actual hardware. Hopefully, it should work.
void emitPinsRandom(int val2emit, int pins[], int pinIni, int pinFinal)
      digitalWrite(pins[pin2emit], HIGH);
      digitalWrite(pins[pin2emit], LOW);
    pin2emit ++;
For example, you can employ it to light a set of patterns on 8 LEDs connected to digital pins 2 to 9 (not sequentially or to any set of pins), using a loop.
  int pins[8] = {2,7,8,9,3,4,5,6};
       emitPinsRandom(LEDS[i], pins, 0, 7);
Thanks.
You may wish to revise your array indices.
You could use it at the beginner level if you set pinMode for the outputs.
  for(int i=2; i<10;i++){
    pinMode(i, OUTPUT);
Done, thanks
(Hint: You don't need pinIni and pinFinal, because specifying them incorrectly will break your function))
Until the person noticed and changed them properly... :slightly_smiling_face:
It is more general. For example, if you want to update just a subset of the pins.
In which case, you probably don't want to start the for loop in the function from 0 ...
Please, notice that the loop is just for the number of pins, not for their locations, which are specified by pinIni and pinFinal.
Then:
  for(int i = pinIni; i <= pinFinal; i++) {
	if(bitRead(val2emit, i-pinIni) == 1)
		digitalWrite(i, HIGH);
		digitalWrite(i, LOW);
Or, until the enums break it
     digitalWrite(i, bitRead(val2emit, i-pinIni));
:smiley:
Nice optimization, thanks. Now, it would be nice that people could widely use it when needed.
