I've tried looking all over and can't seem to find a solution to my problem.
I am trying to set up an IR game, similar to a scavenger hunt, you walk around the course and locate several IR modules, point your IR emitter/encoder at the IR reciever (TSOP4838) connected to an Arduino with an ethernet shield.
The ethernet shield opens up a TCP connection to the point server and adds points based on which IR you hit and what IR device you have.
My problem is the IR transmitting device, right now, I am using random remote controls, it works, but is hokey. (I guess I can say the remote is a phaser).
I would like to find something that can emit a single unique code for that device.
This absolutely seems like it would do the trick http://www.turmlabor.de/wiki/projekte/dslrfernausloeser
A single button, low power requirements, small, light, and I can reprogram the IR code it emits.
I was hoping to find something similar, but pre made. If I had to make hundreds, I would go this route, I just need 10 or 20 though.
I came accross this, http://www.rentron.com/remote_control/TINY-IR2.htm
Not sure if it will do the trick though. Sent an email to their sales, if I can program each circuit with a unique code, then it will work.
Does the community have any ideas? Or am I stuck with giving out the kids "Magic Universe (al) Remotes".
