can you all suggest me with connecting a relay to proxmity sensor the 5v dc relay
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
You need to post you code properly to prevent formatting errors.
Tom.. ![]()
I Made this new code and when the proxmitiy sensor is activated the led is not turning off which is in place of electromagnet
please help me out with this
#include <SoftwareSerial.h>
SoftwareSerial barcode = SoftwareSerial(10, 8, true);
int sensorVal;
float metal;
int reading;
int metalPin = 3;
Serial.println("Barcode Scanner Test!");
pinMode(11, OUTPUT);
// Open the SoftwareSerial port of the barcode scanner
barcode.begin(9600);
{reading = analogRead(metalPin);
metal = (float)reading*100/1024.0;
if(barcode.available())
Serial.println("Read");
char data = barcode.read();
Serial.write(data);
if(reading>250){
digitalWrite(11, LOW);
else{
digitalWrite(11,HIGH);
PLEASE READ POST #21
and do what it says....
Not until you do your part of the bargain and cooperate with us.
PLEASE, get your code in Forum format...
int sensorVal;
float metal;
int reading;
int metalPin = 3;
Serial.write(data);
if(reading>250){
else{
Tom... ![]()
hello so sorry for what happened but i am not able to compile this code to my atmega32 using arduino ide and arduino i have compiled many other but not this please help me out with this
the error i am getting is
exit status 1
Error compiling for board ATmega32-16MHz.
akash614:
exit status 1
That's not the full error: the error pane in the ide has a scroll bar, and/or you can drag the line between the errors and the code up to enlarge it, then post the whole error.
It compiles for a UNO.
Exactly what Arduino controller/board are you using?
A picture of your project will help.
Thanks ... Tom.... ![]()
In file included from C:\Documents and Settings\USER\Desktop\GATES_CODE_OPERATING\GATES_CODE_OPERATING.ino:1:0:
C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src/SoftwareSerial.h:32:0: error: unterminated #ifndef
#ifndef SoftwareSerial_h
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
exit status 1
akash614:
unterminated #ifndef#ifndef SoftwareSerial_h
So it tells you what's wrong there.
It needs a #endif, see here.
What version IDE are you using?
It compiled for me as UNO, on IDE 1.8.3
Tom... ![]()
i am using arduino ide ver 1.8.4
and i am trying to compile the code for atmega32 using arduino as isp then i get this message
i reinstalled arduino as it was not compiling and this message i get
C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp: In member function 'void SoftwareSerial::begin(long int)':
C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp:319:36: error: 'digitalPinToPCICR' was not declared in this scope
if (digitalPinToPCICR(_receivePin)) {
In file included from c:\program files\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
from c:\program files\arduino\hardware\tools\avr\avr\include\avr\interrupt.h:38,
from C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp:41:
C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp:360:76: error: 'digitalPinToPCICRbit' was not declared in this scope
*digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp:363:51: error: 'digitalPinToPCMSK' was not declared in this scope
_pcint_maskreg = digitalPinToPCMSK(_receivePin);
C:\Program Files\Arduino\hardware\arduino\avr\libraries\SoftwareSerial\src\SoftwareSerial.cpp:364:60: error: 'digitalPinToPCMSKbit' was not declared in this scope
_pcint_maskvalue = _BV(digitalPinToPCMSKbit(_receivePin));
exit status 1
