Hello!
I have this display from 3D printer parts. I've used a 16x2 LCD and a 7seg display before, but nothing like this one:
I searched the internet for some info and managed to discover its pinout:
5V ---LCD_CS
BTN_EN0 ---LCD_RESET
BTN_EN1 ---LCD_RS
BTN_EN2 ---SCLK
PUSH_PIN ---MOSI
GND ---MISO
GND ---BUZZER
Then I looked for examples with Arduino and finally I got here: http://www.lcdwiki.com/3.2inch_SPI_Module_ILI9341_SKU:MSP3218#How_to_use_on_Arduino
Hardware connection are these:
Where you see the red lines are unused pins because there are none on my display.
One of the sketches looks something like this:
// IMPORTANT: LCDWIKI_SPI LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
//This program is a demo of displaying string
//when using the BREAKOUT BOARD only and using these hardware spi lines to the LCD,
//the SDA pin and SCK pin is defined by the system and can't be modified.
//if you don't need to control the LED pin,you can set it to 3.3V and set the pin definition to -1.
//other pins can be defined by youself,for example
//pin usage as follow:
// CS DC/RS RESET SDI/MOSI SDO/MISO SCK LED VCC GND
//Arduino Uno A5 A3 A4 11 12 13 A0 5V/3.3V GND
//Remember to set the pins to suit your display module!
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, QD electronic SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
#include <LCDWIKI_GUI.h> //Core graphics library
#include <LCDWIKI_SPI.h> //Hardware-specific library
//paramters define
#define MODEL ILI9341
#define CS A5
#define CD A3
#define RST A4
#define LED A0 //if you don't need to control the LED pin,you should set it to -1 and set it to 3.3V
//the definiens of hardware spi mode as follow:
//if the IC model is known or the modules is unreadable,you can use this constructed function
LCDWIKI_SPI mylcd(MODEL,CS,CD,RST,LED); //model,cs,dc,reset,led
//if the IC model is not known and the modules is readable,you can use this constructed function
//LCDWIKI_SPI mylcd(240,320,CS,CD,RST,LED); //model,cs,dc,reset,led
//define some colour values
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
mylcd.Init_LCD();
mylcd.Fill_Screen(BLACK);
mylcd.Set_Text_Mode(0);
//display 1 times string
mylcd.Fill_Screen(0x0000);
mylcd.Set_Text_colour(RED);
mylcd.Set_Text_Back_colour(BLACK);
mylcd.Set_Text_Size(1);
mylcd.Print_String("Hello World!", 0, 0);
mylcd.Print_Number_Float(01234.56789, 2, 0, 8, '.', 0, ' ');
mylcd.Print_Number_Int(0xDEADBEF, 0, 16, 0, ' ',16);
//mylcd.Print_String("DEADBEF", 0, 16);
//display 2 times string
mylcd.Set_Text_colour(GREEN);
mylcd.Set_Text_Size(2);
mylcd.Print_String("Hello World!", 0, 40);
mylcd.Print_Number_Float(01234.56789, 2, 0, 56, '.', 0, ' ');
mylcd.Print_Number_Int(0xDEADBEF, 0, 72, 0, ' ',16);
//mylcd.Print_String("DEADBEEF", 0, 72);
//display 3 times string
mylcd.Set_Text_colour(BLUE);
mylcd.Set_Text_Size(3);
mylcd.Print_String("Hello World!", 0, 104);
mylcd.Print_Number_Float(01234.56789, 2, 0, 128, '.', 0, ' ');
mylcd.Print_Number_Int(0xDEADBEF, 0, 152, 0, ' ',16);
// mylcd.Print_String("DEADBEEF", 0, 152);
//display 4 times string
mylcd.Set_Text_colour(WHITE);
mylcd.Set_Text_Size(4);
mylcd.Print_String("Hello!", 0, 192);
//display 5 times string
mylcd.Set_Text_colour(YELLOW);
mylcd.Set_Text_Size(5);
mylcd.Print_String("Hello!", 0, 224);
//display 6 times string
mylcd.Set_Text_Size(6);
mylcd.Print_String("Hello!", 0, 266);
delay(3000);
To my surprise, I managed to make it display something, a text, but it is mirrored. Do you have any idea why it behaves like this?
