A library for RAiO RA8875 display by sumotoy
I tested this library on avr and seems working but when i tried to compile the examples attached with arduino due I get too many errors about spi incompatibility , did any go though such probpem?
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp: In member function 'void RA8875::drawPixels(uint16_t*, uint32_t, int16_t, int16_t)':
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp:2138:7: error: 'class SPIClass' has no member named 'transfer16'
SPI.transfer16(p);//should be fixed already
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp: In member function 'uint16_t RA8875::getPixel(int16_t, int16_t)':
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp:2169:16: error: 'class SPIClass' has no member named 'transfer16'
color = SPI.transfer16(0x0);
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp: In member function 'void RA8875::getPixels(uint16_t
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp:2209:7: error: 'class SPIClass' has no member named 'transfer16'
SPI.transfer16(0x0);//dummy
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp:2216:17: error: 'class SPIClass' has no member named 'transfer16'
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp: In member function 'void RA8875::writeData16(uint16_t)':
C:\Arduino\arduino-1.6.3\arduino-1.6.3\libraries\RA8875\RA8875.cpp:3301:7: error: 'class SPIClass' has no member named 'transfer16'
SPI.transfer16(data);//should be fixed alread
That library is specifically built to work on Teensys. I would expect it to work on the Due too. I haven't actually tried it on any Dues yet.
this library is heavy and large and have access to the font flash spi for example when using 7 inch LCD Module w/Optional Capacitive Touch Screen Panel,I2C/SPI , teensy is still with limited, did not test on LaunchPad Tiva yet but hope to see it working on due as part of arduino supporting groups. BUT still could not figure how to use it to access the 2nd SPI flash meant to save graphics on board. or find a an easy way to load the graphics files on the spi flash without the need of external programmer or the sdk-dev kit on www.raio.com.tw as seen on http://www.raio.com.tw/E%20version/e_product.tech3.htm
if you search for previous posts on different topics. you will find my library written especially for the due with the buydisplay 7" capacitive touch screen.
If you have questions or need some help please send me a personal message.
if it works its realy simple.
Kind regards
Johan
Johan,
Kindly show the link for your related post.
