Hi all,
Trying add additional LEDS to my existing sketch. On the micro board Id like to use all 8 PWM outputs which is 13,12,11,10,9,6,5,4. As you can see the sketch Ive been given has only 6 outputs. Ive tried to just copy and paste plus make the needed changes for the extra LEDs but it keeps getting kicked back.
Any help with this so much appreciated.
Thanks.
This script flashes 6 LEDs (yellow, of course) in random order at random intervals using PWM. Each LED is controled by its own function.
int led1 = 3; // LED connected to PWM pin 3, etc. I used all 6 PWM pins.
int led2 = 5;
int led3 = 6;
int led4 = 9;
int led5 = 10;
int led6 = 11;
long randnum; // randnum controls the time interval between flashes and randbug controls which bug lights up.
long randbug;
pinMode(led1, OUTPUT); //Setting all PWM pins as outputs.
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
randbug = random(3, 12); //randbug randomly chooses a function to execute, thus randomly chooses a bug to light up.
if (randbug == 3) {
bug1();
if (randbug == 5) {
bug2();
if (randbug == 6) {
bug3();
if (randbug == 9) {
bug4();
if (randbug == 10) {
bug5();
if (randbug == 11) {
bug6();
void bug1() {
randnum = random(10, 2000);
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) { //each of these functions work the same way. for loops increase then decrease the output of that pin to control LED brightness.
analogWrite(led1, fadeValue); //randnum is a random time interval between 10 and 3000 ms and chooses a time interval between bug flashes.
delay(10); //delay 10 is just for the fade effect.
for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
delay(10);
delay (randnum);
void bug2() {
randnum = random(10, 3000);
analogWrite(led2, fadeValue);
delay(10);
delay(10);
delay (randnum);
void bug3() {
analogWrite(led3, fadeValue);
delay(10);
delay(10);
delay (randnum);
void bug4() {
analogWrite(led4, fadeValue);
delay(10);
delay(10);
delay (randnum);
void bug5() {
analogWrite(led5, fadeValue);
delay(10);
delay(10);
delay (randnum);
void bug6() {
analogWrite(led6, fadeValue);
delay(10);
delay(10);
delay (randnum);
