a little help with building a command in hex string...
Hi guys…
I need to figure out the method how to prepare the command string for the devise…
Device reads the 6 bytes in HEX string as a command so…
like that:
Str2[0]=0x01;
Str2[1]=0x0F;
Str2[2]=0x00;
Str2[3]=0x00;
Str2[4]=0x11;
Str2[5]=(Str2[0]^Str2[1]^Str2[2]^Str2[3]^Str2[4]);
mySerial.write(Str2, sizeof(Str2));
Where is Str[2] , [3] and [4] = the data
each Str2 contains 255 max or FF
Here is a simple scetch I sending a digit from serial monitor the scetch converts the the digit to HEX but it works no problem untill 255 with Str2[4]; which is int E1 in the cketch.
So I need to use Str2[3] byte to exceed 255…
So how to include Str2[3] byte in the code where digit I sending higher then 255…
So actually I got to get 2 INTs from one INT E1 when it’s higher the 255… I pretty sure that there should a mathematical formula but I can’t find it…
I broke my head around this… I know should be simple but…
here is the code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
int E2;
int E1;
String Str;
byte Str2[6];
  Serial.begin(57600);
  Serial.println("Goodnight moon!");
  Serial.setTimeout(10);
   delay(100);
  mySerial.begin(9600);
void loop() // run over and over
    if(Serial.available()>0)
        Str  = Serial.readString();
        delay(10);
        int ch1 = Str.length();
        if(ch1 == 1)
          E1 = Str[0]-48;
          E2=0;
          if(ch1 == 2)
          E1 = ((Str[0]-48)*10)+Str[1]-48;
          E2=0;
          if(ch1 ==3)
         int  E1 = (((Str[0]-48)*10+(Str[1]-48))*10)+(Str[2]-48);
            if(E1 > 255)
Str2[0]=0x01;
Str2[1]=0x0F;
Str2[2]=0x00;
Str2[3]=E2;
Str2[4]=E1;
mySerial.write(Str2, sizeof(Str2)); //20
A byte can only store values up to 255. If you have an int, that is a two byte variable this can be split into two bytes by:-
int number = 12345;
lowerByte = number & 0xff;
upperByte = number >> 8;
Where & is a bit wise AND
is shift right
Grumpy_Mike
Thanks man for kicking me in right direction
E2=E1>>8;
That's it loke always
