so first off, I’m brand new to programming so be nice lol. i frequently find myself in need of a programmer these days so I’m attempting to learn myself but its slow going… i have a project on the go that will involve 3 temp sensors and some outputs to control relays for valves,pumps etc. currently my question relates to this line of code i got from an source online.
void loop(void) {
sensors.requestTemperatures(); // minden eszköztől kérjük a hőmérséklet mérést…
for (int i=0;i<maxsensors;i++)
flashled();
float f = sensors.getTempCByIndex(i); // egyesével kiolvassuk a mért értéket
Serial.print("Sensor ");
Serial.print(i,DEC);
Serial.println(dtostrf(f, 6, 2, buffer));
in particular the last line “Serial.println(dtostrf(f, 6, 2, buffer));” can someone help me understand it?
Reading the how to also applies to the forum Please read it and edit you post to have
[code ]tags around the code
We may not be as case sensitive as the compiler is but we also would like capitals in some places
Then next, lets decompose it.
I assume you know what Serial.println() does? So we can ommit that part. leaves us with dtostrf(). A quick Google give you: Smart | Connected | Secure | Microchip Technology. So it's a way to convert a float number to ASCII text of that number. Humans are not that great at reading just bytes so we prefer text, ASCII is a common/simple way to map byte values to characters (so even numbers like here!)
Why they do it? I have no idea because Arduino IDE has a build in function for that... Maybe the code is old and it wasn't build in at the time but
Serial.println(f, 2); //two decimal places just like dtostrf() used as third argument
