Hi all. Im sergio from italy. I just try to write a post in italian section but no luck until now.
Then I have a 24 volt motor take from a coin hopper , a relay module ( from arduino starter kit ) and a opto sensor module.
Then I have a software in my computer called mamehooker that "sniff" outputs from mame and send via serial to arduino.
I'm able to start relay so turn on my motor when a signal come from serial , but i can't manage this kind of input to do a "countdown" with coins that pass close the sensor. In actual situation , when i send some input, the relay go on but when the first coin pass on the sensor , the relay go off.
I just try some debug codes, for count the input , and it work , another for count the sensor input , and it work too . Please if someone know how i can solve this issue , just say thanks.
I share here the two debug codes i used , and the actual code that work in part.
This is the code i actual use
#define TIME_OUT 500UL
int value = 0;
volatile int credito = 0;
unsigned long myMillis = 0;
bool riscossione = false;
volatile bool ritardo = false;
volatile bool ledONOFF = HIGH;
volatile bool attivaISR = false;
pinMode(3, OUTPUT);
digitalWrite(3, LOW);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
pinMode(2, INPUT);
while (Serial.available() > 0) {
value = Serial.parseInt();
if (Serial.read() == 'x') {
riscossione = true;
myMillis = millis();
if (value > 0) {
credito ++;
if (riscossione && (millis() - myMillis > TIME_OUT)) {
attivaISR = true;
attachInterrupt(digitalPinToInterrupt(2), erogazione, FALLING);
digitalWrite(3, HIGH);
if (ritardo) {
delay(20);
ritardo = false;
detachInterrupt (digitalPinToInterrupt(2));
void erogazione() {
if (attivaISR) {
credito--;
digitalWrite(LED_BUILTIN, ledONOFF);
ledONOFF = !ledONOFF;
if (credito <= 0) {
ritardo = true;
attivaISR = false;
credito = 0;
this is the debug for check if the opto sensor work
int LED = 13; // Use the onboard Uno LED
int isObstaclePin = 2; // This is our input pin
int isObstacle = HIGH; // HIGH MEANS NO OBSTACLE
pinMode(LED, OUTPUT);
pinMode(isObstaclePin, INPUT);
isObstacle = digitalRead(isObstaclePin);
if (isObstacle == LOW)
Serial.println("OBSTACLE!!, OBSTACLE!!");
digitalWrite(LED, HIGH);
Serial.println("clear");
digitalWrite(LED, LOW);
delay(200);
and this is the debug for serial inputs
int pin = 1;
int value = 0;
unsigned long myMillis2 = 0;
volatile bool ledONOFF = LOW;
bool cambioStato = false;
//pin = Serial.parseInt();
riscossione = true;
if (value > 0) {
credito ++;
//Serial.println(pin);
//Serial.print(value);
//Serial.print(" ");
//Serial.println(credito);
if (!cambioStato) {
//Serial.print("erogo ");
//Serial.print(pin);
//Serial.print(" restano ");
//Serial.println(credito-1);
pin++;
cambioStato = true;
myMillis2 = millis();
if (millis() - myMillis2 <= TIME_OUT && credito > 0 && cambioStato) {
digitalWrite(LED_BUILTIN, !ledONOFF);
else if (millis() - myMillis2 > TIME_OUT && credito > 0 && cambioStato) {
credito--;
if (credito == 0) {
//Serial.println("sono qua");
pin = 1;
