i have 2 pushbuttons and one ultrasonic sensor. when i press button 1 then led 1 want to glow and ultrasonic sensor want to wait until detect something in 15cm range. if ultrasonic sensor detect something the relays want to ON. in my code when i press button and at the same time ultrasonic sensor detect something relays are ON. please help me to solve this problem.
here is my code..
const int relay1 = 10;
const int relay2 = 11;
const int trig = 7;
const int echo = 6;
int btn1 = 8;
int btn2 = 9;
int btlight1 = 2;
int btlight2 = 3;
boolean bt1g = true;
boolean bt2g = true;
const int distance = 15; //centrimeters
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
float duration_us , distance_cm;
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(btn1, INPUT_PULLUP);
pinMode(btn2, INPUT_PULLUP);
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
pinMode(btlight1, OUTPUT);
pinMode(btlight2, OUTPUT);
lcd.init();
lcd.backlight();
digitalWrite(btlight1, HIGH);
digitalWrite(btlight2, HIGH);
delay(100);
digitalWrite(btlight1, LOW);
digitalWrite(btlight2, LOW);
delay(100);
digitalWrite(relay1, HIGH);
digitalWrite(relay2, HIGH);
//// BTN1 ////
//if btn1 is on//
if ( digitalRead(btn1) == HIGH ) {
// generate 10s pulse to trig pin //
digitalWrite(trig, HIGH);
delayMicroseconds(10);
digitalWrite(trig, LOW);
// measure duaration of pulse from echo pin//
duration_us = pulseIn(echo, HIGH);
// calculate the distance //
distance_cm = 0.017 * duration_us;
if ( distance_cm < distance ) {
digitalWrite(relay1, LOW);
digitalWrite(relay2, LOW);
Serial.print("btn1:");
Serial.println(1);
delay(5000);
bt1g = false;
//if btn1 is off//
if ( digitalRead(btn1) == LOW ) {
Serial.println(0);
bt1g = true;
////BTN2////
//if btn2 is on//
if ( digitalRead(btn2) == HIGH ) {
Serial.print("btn2:");
Serial.println(1);
bt1g = false;
//if btn2 is off//
if ( digitalRead(btn2) == LOW ) {
Serial.println(0);
bt2g = true;
