I don’t know if I have an Arduino, TTIG or TTN problem or maybe a combination of them. I’m a tutorials guy and following this one step by step…
The Things Indoor Gateway's LED is glowing steady green and it says it’s “connected” on The Things Network (TTN).
I started an application on TTN too.
The Arduino MKR WAN 1310 is a meter away from the gateway and is failing to connect to the TTN when running FirstConfiguration.ino.
From my description and 3 screen shots can you tell what I'm doing wrong or what I should try next?
Thanks
