I found the relevant description in the official documentation of Arduino Uno R4 Wifi that it supports bluetooth connection, but why I can't find it in the bluetooth device list.
Does anyone have the same questions as me?
Thank You very much.
Arduino UNO R4 WiFi Cheat Sheet | Arduino Documentation
#include <ArduinoBLE.h>
while (!Serial);
// begin initialization
if (!BLE.begin()) {
Serial.println("starting Bluetooth® Low Energy module failed!");
while (1);
Serial.println("Bluetooth® Low Energy Central - Peripheral Explorer");
// start scanning for peripherals
BLE.scan();
// check if a peripheral has been discovered
BLEDevice peripheral = BLE.available();
if (peripheral) {
// discovered a peripheral, print out address, local name, and advertised service
Serial.print("Found ");
Serial.print(peripheral.address());
Serial.print(" '");
Serial.print(peripheral.localName());
Serial.print("' ");
Serial.print(peripheral.advertisedServiceUuid());
// check for peripheral's name
if (peripheral.localName() == "<PERIPHERAL_NAME>") {
// stop scanning
BLE.stopScan();
explorerPeripheral(peripheral);
// peripheral disconnected, we are done
while (1) {
// do nothing
void explorerPeripheral(BLEDevice peripheral) {
// connect to the peripheral
Serial.println("Connecting ...");
if (peripheral.connect()) {
Serial.println("Connected");
Serial.println("Failed to connect!");
return;
// discover peripheral attributes
Serial.println("Discovering attributes ...");
if (peripheral.discoverAttributes()) {
Serial.println("Attributes discovered");
Serial.println("Attribute discovery failed!");
peripheral.disconnect();
return;
// read and print device name of peripheral
Serial.print("Device name: ");
Serial.println(peripheral.deviceName());
Serial.print("Appearance: 0x");
Serial.println(peripheral.appearance(), HEX);
// loop the services of the peripheral and explore each
for (int i = 0; i < peripheral.serviceCount(); i++) {
BLEService service = peripheral.service(i);
exploreService(service);
// we are done exploring, disconnect
Serial.println("Disconnecting ...");
Serial.println("Disconnected");
void exploreService(BLEService service) {
// print the UUID of the service
Serial.print("Service ");
Serial.println(service.uuid());
// loop the characteristics of the service and explore each
for (int i = 0; i < service.characteristicCount(); i++) {
BLECharacteristic characteristic = service.characteristic(i);
exploreCharacteristic(characteristic);
void exploreCharacteristic(BLECharacteristic characteristic) {
// print the UUID and properties of the characteristic
Serial.print("\tCharacteristic ");
Serial.print(characteristic.uuid());
Serial.print(", properties 0x");
Serial.print(characteristic.properties(), HEX);
// check if the characteristic is readable
if (characteristic.canRead()) {
// read the characteristic value
characteristic.read();
if (characteristic.valueLength() > 0) {
// print out the value of the characteristic
Serial.print(", value 0x");
printData(characteristic.value(), characteristic.valueLength());
// loop the descriptors of the characteristic and explore each
for (int i = 0; i < characteristic.descriptorCount(); i++) {
BLEDescriptor descriptor = characteristic.descriptor(i);
exploreDescriptor(descriptor);
void exploreDescriptor(BLEDescriptor descriptor) {
// print the UUID of the descriptor
Serial.print("\t\tDescriptor ");
Serial.print(descriptor.uuid());
// read the descriptor value
descriptor.read();
// print out the value of the descriptor
printData(descriptor.value(), descriptor.valueLength());
void printData(const unsigned char data[], int length) {
for (int i = 0; i < length; i++) {
unsigned char b = data[i];
if (b < 16) {
Serial.print("0");
Serial.print(b, HEX);
That's BLE.
As for 'Classic BT', this should work if the UnoR4 WiFi has that functionality. (I don't have one of these, but my ESP32's have 'Classic BT'.)
#include "BluetoothSerial.h"
//#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
//#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
//#endif
BluetoothSerial SerialBT;
SerialBT.begin("ESP32_MLX"); //Bluetooth device name
for(byte idx = 0; idx < 100; idx ++)
SerialBT.println(idx);
Your topic should probably have been posted at --
Latest Hardware/Arduino WiFi Rev2 topics - Arduino Forum
Please do not post in the "Uncategorized" section of the forum? See the sticky topics in https://forum.arduino.cc/c/using-arduino/uncategorized/184.
Topic has been moved.
