I would like to know the solutions to two main problems:
- The communication pin is sending but not yet receiving.
- The PWM and forwarding pin are not toggling.
There also is some unfinished business on the read-out part so nevermind that.
I am currently getting the following error (which might be related to the set pinMode for a pin?):
E (441189) gpio: gpio_set_level(226): GPIO output gpio_num error
There is no easy way to check the pinMode it seems?
The code compiles, the program boots, sends and several functions work:
// An example communication program using a single pin.
// Copyright © Wobbly, 2022.
#include <TimeLib.h>
// The program variables
const int PinCom = 16; // main digital bi-directional communication pin (on the ESP32)
const int PinForward = 17; // secondary forwarding communication pin (on the ESP32)
const int PinVoltage = 2; // analog pin (on the ESP32) to read a voltage from
const int PinPulse = 4; // analog pin (on the ESP32) to generate a pulse on
const int PinLED = 13; // LED indication pin for reception activity
int DeviceVoltage = 3300; // define your operating voltage in mV
int PinComState = LOW; // log the pin state
String SpeedMicrosInput = ""; // used for temporary speed input
unsigned long HighTime = 0; // duration for the HIGH status of the pin
float SpeedMicros = 2000; // set the time allowed for the signal
float Character = SpeedMicros * 2; // set the first character time, low-time and the end signal- time
float SignalDeviation = (SpeedMicros / 2) - 1; // sets the allowed deviation
// int CharacterDelay = 1; // set the delay in between character processing if required
int PWMState = LOW; // check the pulse pin state
float Frequency = 5000; // sets the frequency on the pulse pin in Hz
float DutyCycle = 50; // sets the duty cycle on the pulse pin
float High = (1000000 / Frequency) * (DutyCycle / 100); // used to calculate the HIGH time on the PWM (PulsPin)
float Low = (1000000 / Frequency) - High; // used calculate the LOW time on the PWM (PulsPin)
int AnalogRead = 0; // stores the read value
int Voltage = 0; // stores the voltage
int VoltageReceived = 0; // stores the received voltage
String VoltageRead = ""; // temporarily stores the voltage
String SerialSpeedString = ""; // used for temporary serial speed input
int SerialSpeed = 0; // stores the serial speed
char BootInput = ' '; // boot loading input
boolean PinComSend = false; // flag a send for the Pin
boolean PinComReceive = false; // flag a receive for the Pin
boolean BootMaster = false; // this registers the ID and thereby enables specific functions on the boot
boolean MessageReceived = false; // mark the reception of a message
boolean InitiateFunction = false; // this marks the reception of a function code
boolean TimeCodeReceived = false; // mark the reception of a time-code
boolean Ping = false; // mark the reply message ping
boolean PWM = false; // mark the PWM initiation
boolean Forward = false; // mark the forwarding initiation
char tempChar = ' ';
String MessageString = ""; // the string used for the message
int StringLength = 0; // log the string length
int CharacterCount = 0; // count the amount of characters in a message
int MessagesSent = 0; // count the amount of messages sent
int MessagesReceived = 0; // count the amount of messages received
int CharacterPosition = 0; // checkt the character postion
String ID = "9999"; // used to identify the device, set to 9999 for creating masterboot functions
String IDsender = "0000"; // used to identify the sending device
const String IDadded = " DELIVERED THE FOLLOWING MESSAGE FOR YOU: "; // added string to identify the sender
char FunctionFirstDigit = ' '; // first function value digit picked up from message, combine this to: char FunctionDigits[4] = '';?
char FunctionSecondDigit = ' '; // etc.
char FunctionThirdDigit = ' ';
char FunctionFourthDigit = ' ';
const String SearchFunctionValue = "FUNCTIONVALUE="; // search the position of a possible function value
String FunctionValue = ""; // temporary Function value storage
int FunctionValuePosition = 0; // store the position of the function value within the string
int FunctionIncomingValue = 0; // store the actual value of the function
char TimeCodeFirstDigit = ' '; // first timecode digit picked up from message, combine this to: char TimeCodeDigit[14] = '';?
char TImeCodeSecondDigit = ' ';
char TimeCodeThirdDigit = ' ';
char TimeCodeFourthDigit = ' ';
char TimeCodeFifthDigit = ' ';
char TimeCodeSixthDigit = ' ';
char TimeCodeSeventhDigit = ' ';
char TimeCodeEigthDigit = ' ';
char TimeCodeNinthDigit = ' ';
char TimeCodeTenthDigit = ' ';
char TimeCodeEleventhDigit = ' ';
char TimeCodeTwelvethDigit = ' ';
char TimeCodeThirteenthDigit = ' ';
char TimeCodeFourteenthDigit = ' ';
const String SearchTimeCode = "TIMECODE="; // search the position of a possible Function value
String TimeCode = ""; // temporary Functionvalue storage
int TimeCodePosition = 0; // store the position of the function value within the string
int Year = 0; // store values for the time
int Month = 0;
int Day = 0;
int Hour = 0;
int Minute = 0;
int Second = 0;
String YearString = ""; // store temporary values for the time
String MonthString = "";
String DayString = "";
String HourString = "";
String MinuteString = "";
String SecondString = "";
unsigned long TotalMillis = 0; // defines the total program running time
unsigned long Millis = 0; // stores the millis
unsigned long Micros = 0; // stores the micros
unsigned long MicrosPrevious = 0; // stores elapsed micros
analogReadResolution(10); // set this to 8 or 12 if required, adjust the code accordingly
pinMode(PinCom, INPUT); // configure the pins
pinMode(PinForward, OUTPUT);
pinMode(PinPulse, OUTPUT);
pinMode(PinLED, OUTPUT);
digitalWrite(PinForward, LOW);
digitalWrite(PinPulse, LOW);
digitalWrite(PinLED, LOW);
SerialSpeed = 9600;
Serial.begin(SerialSpeed); // set the serial at speed
delay(3000);
BeginInputSerial:
Millis = millis();
Serial.println("The default speed for the serial monitor is set to 9600, would you like to change it? If so press 'y' if not press 'n'...");
while (Serial.available() == 0) {
if (millis() - Millis >= 20000) {
Serial.println("20 seconds timed-out... A new serial speed was not set...");
Millis = millis();
goto escapeSetupSerial;
if (Serial.available() > 0) {
BootInput = Serial.read();
Millis = millis();
if (BootInput == 'y') {
Serial.println("Please input the required serial speed in baud: ");
Millis = millis();
BootInput = ' ';
ReInputSerial:
Millis = millis();
if (Serial.available() >= 1) {
SerialSpeedString = Serial.readString();
SerialSpeed = SerialSpeedString.toInt();
if (SerialSpeed != 300 && SerialSpeed != 1200 && SerialSpeed != 2400 && SerialSpeed != 4800 && SerialSpeed != 9600 && SerialSpeed != 19200 && SerialSpeed != 38400 && SerialSpeed != 57600 && SerialSpeed != 74880 && SerialSpeed != 115200 && SerialSpeed != 230400 && SerialSpeed != 250000 && SerialSpeed != 500000 && SerialSpeed != 1000000 && SerialSpeed != 2000000) {
Serial.println("This is number is not valid for the serial monitor speed.");
Serial.print("You tried: ");
Serial.print(SerialSpeed);
Serial.println(" ;it accepts 300, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 74880, 115200, 230400, 250000, 500000, 1000000 or 2000000, please try again:");
BootInput = ' ';
Millis = millis();
goto ReInputSerial;
Serial.print("The new serial speed is: ");
Serial.println(SerialSpeed);
Millis = millis();
Serial.println("Restarting the serial...");
delay(3000);
Serial.end();
delay(3000);
Serial.begin(SerialSpeed); // restart the serial with the new requirements
delay(3000);
if (BootInput == 'n') {
Serial.println("Proceeding with the default serial speed of 9600... ");
Millis = millis();
BootInput = ' ';
if (BootInput != 'n' && BootInput != 'y') {
Serial.println("Input unknown, please try again...");
Millis = millis();
BootInput = ' ';
Serial.flush();
goto BeginInputSerial;
escapeSetupSerial:
BeginInputTime:
TimeCode = "";
Millis = millis();
Serial.println("Would you like to set the internal program time using a time-code (YYYYMMDDHHMMSS)? If so press 'y' if not press 'n'...");
Serial.println("20 seconds timed-out... The time was not set...");
Millis = millis();
goto escapeSetupTime;
Serial.println("Please input the fourteen digit time-code:");
Millis = millis();
BootInput = ' ';
ReInputTime:
Serial.println("20 seconds timed-out... The new time was not set...");
Millis = millis();
TimeCode = Serial.readString();
Serial.println("Setting time, please wait...");
TimeCodeFirstDigit = TimeCode.charAt(0); // read the chars
TImeCodeSecondDigit = TimeCode.charAt(1);
TimeCodeThirdDigit = TimeCode.charAt(2);
TimeCodeFourthDigit = TimeCode.charAt(3);
TimeCodeFifthDigit = TimeCode.charAt(4);
TimeCodeSixthDigit = TimeCode.charAt(5);
TimeCodeSeventhDigit = TimeCode.charAt(6);
TimeCodeEigthDigit = TimeCode.charAt(7);
TimeCodeNinthDigit = TimeCode.charAt(8);
TimeCodeTenthDigit = TimeCode.charAt(9);
TimeCodeEleventhDigit = TimeCode.charAt(10);
TimeCodeTwelvethDigit = TimeCode.charAt(11);
TimeCodeThirteenthDigit = TimeCode.charAt(12);
TimeCodeFourteenthDigit = TimeCode.charAt(13);
YearString.concat(TimeCodeFirstDigit);
YearString.concat(TImeCodeSecondDigit);
YearString.concat(TimeCodeThirdDigit);
YearString.concat(TimeCodeFourthDigit);
MonthString.concat(TimeCodeFifthDigit);
MonthString.concat(TimeCodeSixthDigit);
DayString.concat(TimeCodeSeventhDigit);
DayString.concat(TimeCodeEigthDigit);
HourString.concat(TimeCodeNinthDigit);
HourString.concat(TimeCodeTenthDigit);
MinuteString.concat(TimeCodeEleventhDigit);
MinuteString.concat(TimeCodeTwelvethDigit);
SecondString.concat(TimeCodeThirteenthDigit);
SecondString.concat(TimeCodeFourteenthDigit);
Year = YearString.toInt();
Month = MonthString.toInt();
Day = DayString.toInt();
Hour = HourString.toInt();
Minute = MinuteString.toInt();
Second = SecondString.toInt();
YearString = "";
MonthString = "";
DayString = "";
HourString = "";
MinuteString = "";
SecondString = "";
setTime(Hour,Minute,Second,Day,Month,Year);
delay(3000);
Serial.print("The following time-code was received: ");
Serial.println(TimeCode);
Serial.print("Which makes the new time and date: ");
Serial.print(hour());
Serial.print(":");
Serial.print(minute());
Serial.print(":");
Serial.print(second());
Serial.print(" on day ");
Serial.print(day());
Serial.print(" in monthnumber ");
Serial.print(month());
Serial.print(" of the year ");
Serial.println(year());
Year = 0;
Month = 0;
Day = 0;
Hour = 0;
Minute = 0;
Second = 0;
Millis = millis();
Serial.println("Proceeding without setting the time... ");
Millis = millis();
BootInput = ' ';
Millis = millis();
BootInput = ' ';
Serial.flush();
delay(3000);
goto BeginInputTime;
escapeSetupTime:
ID = 9999;
Serial.print("The default four digit device ID currently is: ");
Serial.println(ID);
BeginInputName:
Millis = millis();
Serial.println("Would you like to set a new four digit device ID (set it to '9999' to enable masterboot functions)? If so press 'y' if not press 'n'...");
Serial.println("The masterboot functions currently entail the forwarding of time to all the listening devices.");
Serial.println("20 seconds timed-out... A new device ID was not set...");
Millis = millis();
goto escapeSetupName;
Millis = millis();
Serial.println("Please input a new device ID made from four digits (like: 0001): ");
BootInput = ' ';
ReInputName:
Millis = millis();
if (Serial.available() == 4) {
ID = Serial.readString();
Serial.print("The new device ID is: ");
Serial.println(ID);
Millis = millis();
if (Serial.available() <= 3 || Serial.available() >= 5) {
Serial.println("Please input four digit device ID (like: 0001), please try again:");
Millis = millis();
goto ReInputName;
Serial.println("Proceeding with the old device ID... ");
BootInput = ' ';
BootInput = ' ';
Serial.flush();
delay(3000);
goto BeginInputName;
escapeSetupName:
if (ID == "9999") {
BootMaster = true;
if (ID != "9999") {
BootMaster = false;
SpeedMicros = 2000;
Serial.print("The current maximum signal speed is set at microseconds: ");
Serial.println(SpeedMicros);
BeginInputSpeed:
Millis = millis();
Serial.println("The default speed is 2000 microseconds. Would you like to set a new maximum signal speed? If so press 'y' if not press 'n'...");
Serial.println("Please do not forget to match the maximum signal speed for all devices to enable communications.");
Serial.println("20 seconds timed-out... A new signal speed was not set...");
Millis = millis();
goto escapeSetupSpeed;
Serial.println("Please input a new maximum signal speed with a minimum of 2 and a maximum of 10000000 microseconds: ");
Millis = millis();
BootInput = ' ';
ReInputSpeed:
Serial.println("20 seconds timed-out... A new maximum signal speed was not set...");
Millis = millis();
if (Serial.available() >= 1 && Serial.available() <= 8) {
SpeedMicrosInput = Serial.readString();
SpeedMicros = SpeedMicrosInput.toInt();
if (SpeedMicros <= 2 || SpeedMicros >= 10000000) {
Serial.print("That is either too fast or too slow, please try again:");
Millis = millis();
delay(1000);;
goto ReInputSpeed;
Serial.print("The maximum signal speed was set to: ");
Serial.print(SpeedMicros);
Serial.println(" microseconds.");
if (Serial.available() >= 9) {
Serial.println("That is too fast, please try again:");
Millis = millis();
goto ReInputSpeed;
Serial.println("Proceeding with the old maximum signal speed... ");
BootInput = ' ';
BootInput = ' ';
Serial.flush();
delay(3000);
goto BeginInputSpeed;
escapeSetupSpeed:
Serial.println("Exiting setup... ");
Serial.println("Welcome to the Wobbly demonstration communication program!");
Serial.println("Message length is limited to 800 Characters minus the included name and opening text added to each message.");
Serial.println("Not every character was coded. More characters, words or direct function recognization can be added with a change in code.");
Serial.println("Always use TABS for message letter input as seen below. The currently coded characters are:");
Serial.println("A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, -, ., , ?, -, =, :, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9");
Serial.println("Four digit function values or fourteen digit time-codes (YYYYMMDDHHMMSS) are detected inside the message automatically when using the following formats: FUNCTIONVALUE=, TIMECODE=");
Serial.println("The function values can be set at any time by inputting 'f' or fourteen digit time-codes (YYYYMMDDHHMMSS) by inputting 't' through the serial monitor, they are then initiated and transmitted.");
Serial.println("With added coded one can call and transmit function values or time-codes automatically at specific events. Or add things like an NTP retrieval, RTCs or RF transmissions");
Serial.println("Currently the following function values are programmed...");
Serial.println("Everything between 0000-5000 is reserved for a voltage, 6001-6999 sets the PWM output frequency in kHz, 7001-7100 sets the PWM duty-cycle, 7101 starts PWM, 7102 stops it, 7103 measures a voltage, 7104 sets the device voltage to 3.3V, 7105 sets it to 5V, 7107 starts foorwarding and 7106 stops forwarding, ");
MessageString = "";
VoltageRead = "";
BootInput = ' ';
Ping = false;
PinComSend = false;
Ping = false;
PWM = false;
Forward = false;
PWMState = LOW;
PinComState = LOW;
AnalogRead = 0;
Voltage = 0;
Frequency = 5000;
DutyCycle = 50;
MessagesSent = 0;
CharacterCount = 0;
StringLength = 0;
HighTime = 0;
MicrosPrevious = 0;
TotalMillis = millis();
Millis = millis();
Serial.flush();
Millis = millis();
Micros = micros();
// temporarily catch a sub-zero value, some problem occured
//if (Frequency <= 0 || DutyCycle <= 0 || SpeedMicros <= 0 || DeviceVoltage <= 0) {
// Frequency = 5000;
// DutyCycle = 50;
// SpeedMicros = 2000;
// DeviceVoltage = 3300;
// monitor the communication pin
PinComState = digitalRead(PinCom);
if (PinComState == HIGH) {
HighTime = Micros;
digitalWrite(PinLED, HIGH);
if (PinComState == LOW) {
// pulseInt compiles but provides a in-program error on the ESP32
//PinPulseTimeOut = (Character + (44 * SpeedMicros) + (SignalDeviation); // calculates the time-out
//HighTime = pulseIn(PinCom, HIGH, PinPulseTimeOut);
// drive the PWM if enabled
if (PWM == true && PWMState == LOW && (Micros - MicrosPrevious) >= Low) {
PWMState = HIGH;
digitalWrite(PinPulse, PWMState);
MicrosPrevious = micros();
if (PWM == true && PWMState == HIGH && (Micros - MicrosPrevious >= High)) {
PWMState = LOW;
if (PWM == false) {
PWMState = LOW;
// drive the forwarding pin (it forwards receiving messages only)
if (Forward == true) {
if (PinComState == HIGH){
digitalWrite(PinForward, PinComState);
else if (PinComState == LOW){
if (Forward == false) {
// start receiving
if (PinComSend == false && (HighTime - Micros) >= (Character - SignalDeviation)) {
if (HighTime >= (Character - SignalDeviation) && HighTime <= (Character + SignalDeviation) && PinComReceive == true) // detect a character
MessageString.concat(tempChar);
CharacterCount = CharacterCount + 1; // count the characters
tempChar = ' ';
else if (HighTime >= (Character + (1 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (1 * SpeedMicros) + SignalDeviation) && Ping == false) // message opening signal
CharacterCount = 0;
PinComReceive = true;
else if (HighTime >= (Character + (1 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (1 * SpeedMicros) + SignalDeviation) && PinComReceive == true && Ping == true) // message block opening signal
Ping = false; // this ignores the opening signal and blocks the return message from going back and forth
else if (HighTime >= (Character + (2 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (2 * SpeedMicros) + SignalDeviation) && PinComReceive == true) // message closing signal
MessageReceived = true;
Serial.print("Here is your message with ");
Serial.print(StringLength);
Serial.println(" characters in the string:");
Serial.println(MessageString); // and print them all together
delay(5000);
IDsender = "";
IDsender = MessageString.concat(0);
IDsender = MessageString.concat(1);
IDsender = MessageString.concat(2);
IDsender = MessageString.concat(3);
FunctionValuePosition = MessageString.indexOf(SearchFunctionValue); // add Function value or other recognization functionality later
if (FunctionValuePosition >= 0) {
FunctionFirstDigit = MessageString.charAt(FunctionValuePosition + 1); // possible add 12 more depending on the reported position
FunctionSecondDigit = MessageString.charAt(FunctionValuePosition + 2);
FunctionThirdDigit = MessageString.charAt(FunctionValuePosition + 3);
FunctionFourthDigit = MessageString.charAt(FunctionValuePosition + 4);
FunctionValue += FunctionFirstDigit;
FunctionValue += FunctionSecondDigit;
FunctionValue += FunctionThirdDigit;
FunctionValue += FunctionFourthDigit;
FunctionIncomingValue = FunctionValue.toInt();
Serial.print("We picked up a Function value stating: ");
Serial.println(FunctionIncomingValue);
FunctionValue = "";
InitiateFunction = true;
delay(3000);
TimeCodePosition = MessageString.indexOf(SearchTimeCode); // retrieve the time-code and thereby the time
if (TimeCodePosition >= 0) {
Year = 0;
Month = 0;
Day = 0;
Hour = 0;
Minute = 0;
Second = 0;
YearString = "";
MonthString = "";
DayString = "";
HourString = "";
MinuteString = "";
SecondString = "";
TimeCodeFirstDigit = MessageString.charAt(TimeCodePosition + 1); // possible add 9 (TIMECODE=) more depending on the reported position
TImeCodeSecondDigit = MessageString.charAt(TimeCodePosition + 2);
TimeCodeThirdDigit = MessageString.charAt(TimeCodePosition + 3);
TimeCodeFourthDigit = MessageString.charAt(TimeCodePosition + 4);
TimeCodeFifthDigit = MessageString.charAt(TimeCodePosition + 5);
TimeCodeSixthDigit = MessageString.charAt(TimeCodePosition + 6);
TimeCodeSeventhDigit = MessageString.charAt(TimeCodePosition + 7);
TimeCodeEigthDigit = MessageString.charAt(TimeCodePosition + 8);
TimeCodeNinthDigit = MessageString.charAt(TimeCodePosition + 9);
TimeCodeTenthDigit = MessageString.charAt(TimeCodePosition + 10);
TimeCodeEleventhDigit = MessageString.charAt(TimeCodePosition + 11);
TimeCodeTwelvethDigit = MessageString.charAt(TimeCodePosition + 12);
TimeCodeThirteenthDigit = MessageString.charAt(TimeCodePosition + 13);
TimeCodeFourteenthDigit = MessageString.charAt(TimeCodePosition + 14);
TimeCode += TimeCodeFirstDigit;
TimeCode += TImeCodeSecondDigit;
TimeCode += TimeCodeThirdDigit;
TimeCode += TimeCodeFourthDigit;
TimeCode += TimeCodeFifthDigit;
TimeCode += TimeCodeSixthDigit;
TimeCode += TimeCodeSeventhDigit;
TimeCode += TimeCodeEigthDigit;
TimeCode += TimeCodeNinthDigit;
TimeCode += TimeCodeTenthDigit;
TimeCode += TimeCodeEleventhDigit;
TimeCode += TimeCodeTwelvethDigit;
TimeCode += TimeCodeThirteenthDigit;
TimeCode += TimeCodeFourteenthDigit;
Year = 0;
Month = 0;
Day = 0;
Hour = 0;
Minute = 0;
Second = 0;
YearString = "";
MonthString = "";
DayString = "";
HourString = "";
MinuteString = "";
SecondString = "";
Serial.print(":");
Serial.print(":");
Serial.print(" on the ");
Serial.print(" day in monthnumber ");
TimeCodeReceived = true;
TimeCode = "";
Serial.println("Waiting to send or receive a new message...");
Serial.flush();
CharacterCount = 0;
++MessagesReceived;
MessageString = "";
Ping = false;
else if (HighTime >= (Character + (3 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (3 * SpeedMicros) + SignalDeviation))
tempChar = '0';
else if (HighTime >= (Character + (4 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (4 * SpeedMicros) + SignalDeviation))
tempChar = '1';
else if (HighTime >= (Character + (5 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (5 * SpeedMicros) + SignalDeviation))
tempChar = '2';
else if (HighTime >= (Character + (6 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (6 * SpeedMicros) + SignalDeviation))
tempChar = '3';
else if (HighTime >= (Character + (7 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (7 * SpeedMicros) + SignalDeviation))
tempChar = '4';
else if (HighTime >= (Character + (8 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (8 * SpeedMicros) + SignalDeviation))
tempChar = '5';
else if (HighTime >= (Character + (9 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (9 * SpeedMicros) + SignalDeviation))
tempChar = '6';
else if (HighTime >= (Character + (10 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (10 * SpeedMicros) + SignalDeviation))
tempChar = '7';
else if (HighTime >= (Character + (11 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (11 * SpeedMicros) + SignalDeviation))
tempChar = '8';
else if (HighTime >= (Character + (12 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (12 * SpeedMicros) + SignalDeviation))
tempChar = '9';
else if (HighTime >= (Character + (13 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (13 * SpeedMicros) + SignalDeviation))
tempChar = '-';
else if (HighTime >= (Character + (14 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (14 * SpeedMicros) + SignalDeviation))
tempChar = '.';
else if (HighTime >= (Character + (15 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (15 * SpeedMicros) + SignalDeviation))
tempChar = ' ';
else if (HighTime >= (Character + (16 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (16 * SpeedMicros) + SignalDeviation))
tempChar = '?';
else if (HighTime >= (Character + (17 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (17 * SpeedMicros) + SignalDeviation))
tempChar = '=';
else if (HighTime >= (Character + (18 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (18 * SpeedMicros) + SignalDeviation))
tempChar = ':';
else if (HighTime >= (Character + (19 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (19 * SpeedMicros) + SignalDeviation))
tempChar = 'A';
else if (HighTime >= (Character + (20 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (20 * SpeedMicros) + SignalDeviation))
tempChar = 'B';
else if (HighTime >= (Character + (21 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (21 * SpeedMicros) + SignalDeviation))
tempChar = 'C';
else if (HighTime >= (Character + (22 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (22 * SpeedMicros) + SignalDeviation))
tempChar = 'D';
else if (HighTime >= (Character + (23 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (23 * SpeedMicros) + SignalDeviation))
tempChar = 'E';
else if (HighTime >= (Character + (24 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (24 * SpeedMicros) + SignalDeviation))
tempChar = 'F';
else if (HighTime >= (Character + (25 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (25 * SpeedMicros) + SignalDeviation))
tempChar = 'G';
else if (HighTime >= (Character + (26 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (26 * SpeedMicros) + SignalDeviation))
tempChar = 'H';
else if (HighTime >= (Character + (27 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (27 * SpeedMicros) + SignalDeviation))
tempChar = 'I';
else if (HighTime >= (Character + (28 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (28 * SpeedMicros) + SignalDeviation))
tempChar = 'J';
else if (HighTime >= (Character + (29 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (29 * SpeedMicros) + SignalDeviation))
tempChar = 'K';
else if (HighTime >= (Character + (30 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (30 * SpeedMicros) + SignalDeviation))
tempChar = 'L';
else if (HighTime >= (Character + (31 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (31 * SpeedMicros) + SignalDeviation))
tempChar = 'M';
else if (HighTime >= (Character + (32 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (32 * SpeedMicros) + SignalDeviation))
tempChar = 'N';
else if (HighTime >= (Character + (33 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (33 * SpeedMicros) + SignalDeviation))
tempChar = 'O';
else if (HighTime >= (Character + (34 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (34 * SpeedMicros) + SignalDeviation))
tempChar = 'P';
else if (HighTime >= (Character + (35 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (35 * SpeedMicros) + SignalDeviation))
tempChar = 'Q';
else if (HighTime >= (Character + (36 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (36 * SpeedMicros) + SignalDeviation))
tempChar = 'R';
else if (HighTime >= (Character + (37 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (37 * SpeedMicros) + SignalDeviation))
tempChar = 'S';
else if (HighTime >= (Character + (38 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (38 * SpeedMicros) + SignalDeviation))
tempChar = 'T';
else if (HighTime >= (Character + (39 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (39 * SpeedMicros) + SignalDeviation))
tempChar = 'U';
else if (HighTime >= (Character + (40 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (40 * SpeedMicros) + SignalDeviation))
tempChar = 'V';
else if (HighTime >= (Character + (41 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (41 * SpeedMicros) + SignalDeviation))
tempChar = 'W';
else if (HighTime >= (Character + (42 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (42 * SpeedMicros) + SignalDeviation))
tempChar = 'X';
else if (HighTime >= (Character + (43 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (43 * SpeedMicros) + SignalDeviation))
tempChar = 'Y';
else if (HighTime >= (Character + (44 * SpeedMicros) - SignalDeviation) && HighTime <= (Character + (44 * SpeedMicros) + SignalDeviation))
tempChar = 'Z';
else if (HighTime > (Character + (44 * SpeedMicros) + SignalDeviation)) // unknown signal
tempChar = ' ';
goto EscapeInput;
Serial.println("Reception error: signals too long...");
HighTime = 0;
// confirm the message reception
if (MessageReceived == true && Ping == false && PinComSend == false && PinComReceive == false) {
if (TimeCodeReceived == true && InitiateFunction == true){
MessageString = " WE HAVE RECEIVED YOUR MESSAGE CONTAINING THE TIME-CODE AND FUNCTION VALUE!";
MessageString = IDsender + MessageString;
MessageString = ID + IDadded + MessageString;
if (TimeCodeReceived == true){
MessageString = " WE HAVE RECEIVED YOUR MESSAGE CONTAINING THE TIME-CODE!";
if (InitiateFunction == true){
MessageString = " WE HAVE RECEIVED YOUR MESSAGE CONTAINING THE FUNCTION VALUE!";
else {
MessageString = " WE HAVE RECEIVED YOUR MESSAGE!";
Ping = true;
goto DigitalInput;
// boot routine for the massterboot functions, add more if you like
if (BootMaster == true && PinComReceive == false) {
Serial.println("Entering bootmaster sequence... Sending time-code...");
// create time-code and provide functionvalue
MessageString = "TIMECODE=";
MessageString = ID + IDadded + MessageString + TimeCode;
Serial.println("The following bootmessage was generated containing a time-code (YYYYMMHHMMSS): ");
BootMaster = false;
TimeCode = "";
goto DigitalInput;
if (Millis - TotalMillis >= 60000 && PinComSend == false && PinComReceive == false) {
Serial.println("No message activity for 60 seconds...");
Serial.print("The program has been running for ");
Serial.print(Millis/1000);
Serial.print(" seconds. With ");
Serial.print(MessagesSent);
Serial.print(" messages sent and ");
Serial.print(MessagesReceived);
Serial.println(" received.");
Serial.flush();
EscapeInput:
while (Serial.available() == 0 && PinComSend == false && PinComReceive == false) {}
if (Serial.available() >= 1 && PinComSend == false && PinComReceive == false) {
MessageString = Serial.readString();
Serial.flush();
if (MessageString == "f") {
MessageString = "";
Millis = millis();
Serial.println("Please input a four digit function value to initiate the function: ");
ReInputFunction:
Serial.println("20 seconds timed-out... No function value was received...");
pinMode (PinCom, INPUT);
goto EscapeInput;
FunctionValue = Serial.readString();
Serial.print("Function: ");
Serial.print(FunctionIncomingValue);
Serial.println(", initiated...");
AutoInitiateFunction: // entrypoint for automatic trigger
MessageString = "FUNCTIONVALUE=";
MessageString = MessageString + FunctionValue;
goto DigitalInput;
Serial.println("Input a four digit value from 0001 to 9999, please try again:");
Millis = millis();
goto ReInputFunction;
if (MessageString == "t") {
MessageString = "";
Millis = millis();
Serial.println("Please input the time-code (YYYYMMDDHHMMSS):");
ReInputTime:
goto EscapeInput;
if (Serial.available() == 14) {
YearString = "";
MonthString = "";
DayString = "";
HourString = "";
MinuteString = "";
SecondString = "";
Year = 0;
Month = 0;
Day = 0;
Hour = 0;
Minute = 0;
Second = 0;
Serial.print(":");
Serial.print(":");
Serial.print(" on ");
AutoInitiateTime: // entrypoint for automatic trigger
MessageString = MessageString + TimeCode;
TimeCode = "";
goto DigitalInput;
if (Serial.available() <= 13 || Serial.available() >= 15) {
Serial.println("Input a fourteen digit value for the time-code , please try again:");
Millis = millis();
goto ReInputTime;
DigitalInput:
PinComSend = true;
pinMode(PinCom, OUTPUT);
StringLength = 0;
CharacterCount = 0;
StringLength = MessageString.length() + 1;
tempChar = MessageString.charAt(CharacterPosition);
if (StringLength >= 800) {
Serial.println("Your message contained more than 800 Characters, this is not allowed. Please try again. You tried the following message:");
goto EscapeInput;
digitalWrite(PinCom, HIGH); // pre-pulse the pin
delayMicroseconds(SpeedMicros);
digitalWrite(PinCom, LOW);
digitalWrite(PinCom, HIGH); // send the opening signal
delayMicroseconds(Character + (1 * SpeedMicros));
delayMicroseconds(Character);
ReadChars:
if (tempChar == '0') {
delayMicroseconds(Character + (3 * SpeedMicros)); // set these values to change the speed of the connection, decreasing the signal width will improve connection speed but reliability might lack depending on the microprocessor
delayMicroseconds(Character); // the LOW time is not detected but one could change the code to detcct a LOW using the PinMode PULLUP funcion ofr PinCom
digitalWrite(PinCom, HIGH); // send the character end signal
CharacterCount = CharacterCount + 1; // count the characters send
else if (tempChar == '1') {
delayMicroseconds(Character + (4 * SpeedMicros));
else if (tempChar == '2') {
delayMicroseconds(Character + (5 * SpeedMicros));
else if (tempChar == '3') {
delayMicroseconds(Character + (6 * SpeedMicros));
else if (tempChar == '4') {
delayMicroseconds(Character + (7 * SpeedMicros));
else if (tempChar == '5') {
delayMicroseconds(Character + (8 * SpeedMicros));
else if (tempChar == '6') {
delayMicroseconds(Character + (9 * SpeedMicros));
else if (tempChar == '7') {
delayMicroseconds(Character + (10 * SpeedMicros));
else if (tempChar == '8') {
delayMicroseconds(Character + (11 * SpeedMicros));
else if (tempChar == '9') {
delayMicroseconds(Character + (12 * SpeedMicros));
else if (tempChar == '-') {
delayMicroseconds(Character + (13 * SpeedMicros));
else if (tempChar == '.') {
delayMicroseconds(Character + (14 * SpeedMicros));
else if (tempChar == ' ') {
delayMicroseconds(Character + (15 * SpeedMicros));
else if (tempChar == '?') {
delayMicroseconds(Character + (16 * SpeedMicros));
else if (tempChar == '=') {
delayMicroseconds(Character + (17 * SpeedMicros));
else if (tempChar == ':') {
delayMicroseconds(Character + (18 * SpeedMicros));
else if (tempChar == 'A') {
delayMicroseconds(Character + (19 * SpeedMicros));
else if (tempChar == 'B') {
delayMicroseconds(Character + (20 * SpeedMicros));
else if (tempChar == 'C') {
delayMicroseconds(Character + (21 * SpeedMicros));
else if (tempChar == 'D') {
delayMicroseconds(Character + (22 * SpeedMicros));
else if (tempChar == 'E') {
delayMicroseconds(Character + (23 * SpeedMicros));
else if (tempChar == 'F') {
delayMicroseconds(Character + (24 * SpeedMicros));
else if (tempChar == 'G') {
delayMicroseconds(Character + (25 * SpeedMicros));
else if (tempChar == 'H') {
delayMicroseconds(Character + (26 * SpeedMicros));
else if (tempChar == 'I') {
delayMicroseconds(Character + (27 * SpeedMicros));
else if (tempChar == 'J') {
delayMicroseconds(Character + (28 * SpeedMicros));
else if (tempChar == 'K') {
delayMicroseconds(Character + (29 * SpeedMicros));
else if (tempChar == 'L') {
delayMicroseconds(Character + (30 * SpeedMicros));
else if (tempChar == 'M') {
delayMicroseconds(Character + (31 * SpeedMicros));
else if (tempChar == 'N') {
delayMicroseconds(Character + (32 * SpeedMicros));
else if (tempChar == 'O') {
delayMicroseconds(Character + (33 * SpeedMicros));
else if (tempChar == 'P') {
delayMicroseconds(Character + (34 * SpeedMicros));
else if (tempChar == 'Q') {
delayMicroseconds(Character + (35 * SpeedMicros));
else if (tempChar == 'R') {
delayMicroseconds(Character + (36 * SpeedMicros));
else if (tempChar == 'S') {
delayMicroseconds(Character + (37 * SpeedMicros));
else if (tempChar == 'T') {
delayMicroseconds(Character + (38 * SpeedMicros));
else if (tempChar == 'U') {
delayMicroseconds(Character + (39 * SpeedMicros));
else if (tempChar == 'V') {
delayMicroseconds(Character + (40 * SpeedMicros));
else if (tempChar == 'W') {
delayMicroseconds(Character + (41 * SpeedMicros));
else if (tempChar == 'X') {
delayMicroseconds(Character + (42 * SpeedMicros));
else if (tempChar == 'Y') {
delayMicroseconds(Character + (43 * SpeedMicros));
else if (tempChar == 'Z') {
delayMicroseconds(Character + (44 * SpeedMicros));
else { // used when the character a not recognized
delayMicroseconds(Character + (15 * SpeedMicros)); // sends an empty space
if (CharacterPosition <= StringLength) {
++CharacterPosition;
// delayMicroseconds(CharacterDelay); // check if required
goto ReadChars;
if (CharacterPosition > StringLength) {
digitalWrite(PinCom, HIGH); // send the messsage end signal
delayMicroseconds(Character + (2 * SpeedMicros));
Serial.print("The following message was sent containing ");
Serial.println(" characters:");
tempChar = ' ';
CharacterCount = 0;
StringLength = 0;
MessageString = "";
++MessagesSent;
PinComSend = false;
Serial.flush();
// used for several example program features based on the detected function value, the numbers chosen are totally random, 9999 options here...
if (FunctionIncomingValue >= 0001 && FunctionIncomingValue <= 5000 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
VoltageReceived = FunctionIncomingValue; // converts the voltage to mV
Serial.print("The voltage from the sender with device ID: ");
Serial.print(IDsender);
Serial.print(" reads");
Serial.print(VoltageReceived);
Serial.println(" mV");
delayMicroseconds(1000);
// set the Frequency in kHz
if (FunctionIncomingValue >= 6001 && FunctionIncomingValue <= 6999 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
Frequency = (FunctionIncomingValue - 6000) * 1000;
Serial.print("The frequency was set to: ");
Serial.print(Frequency);
Serial.println("Hz");
// set the DutyCycle
if (FunctionIncomingValue >= 7001 && FunctionIncomingValue <= 7100 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
DutyCycle = FunctionIncomingValue - 7000;
Serial.print("The duty-cycle for the frequency was set to: ");
Serial.print(DutyCycle);
Serial.println("%");
// start the PWM
if (FunctionIncomingValue == 7101 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
PWM = true;
PWMState = LOW;
// if (Frequency <= 0 || DutyCycle <= 0) {
// DutyCycle = 50;
// Serial.println();
// Serial.println("Either the frequency or duty-cycle was smaller than zero and both were resetted to default, how did that happen?");
Serial.print("PWM engaged at ");
Serial.print("Hz with a ");
Serial.print("% duty-cycle with a low-time of ");
Serial.print(Low);
Serial.print(" microseconds and a high-time ");
Serial.print(High);
// stop the PWM
if (FunctionIncomingValue == 7102 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
PWM = false;
PWMState = LOW;
Serial.println("PWM disengaged...");
// read and report the analog voltage
if (FunctionIncomingValue == 7103 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
AnalogRead = analogRead(PinVoltage);
Voltage = DeviceVoltage / 1024 * AnalogRead; // in mV
VoltageRead = String(Voltage);
MessageString = "THE FUNCTIONVALUE=";
MessageString = MessageString + VoltageRead;
Serial.print("The voltage reads: ");
Serial.print(Voltage);
Serial.println("mV");
VoltageRead = "";
goto DigitalInput;
// start communication forwarding on the forwarding pin
if (FunctionIncomingValue == 7104 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
Serial.println("Device operating voltage set to 3.3V...");
// stop communication forwarding on the forwarding pin
if (FunctionIncomingValue == 7105 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
DeviceVoltage = 5000;
Serial.println("Device operating voltage set to 5V...");
if (FunctionIncomingValue == 7106 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
Forward = true;
Serial.println("Forwarding enabled...");
if (FunctionIncomingValue == 7107 && InitiateFunction == true && PinComSend == false && PinComReceive == false && Ping == false) {
Forward = false;
Serial.println("Forwarding disabled...");
I made it suitable for use on most microprocessors and therefore I removed EEPROM, NTP and RTC functions. Let me know what you think. Things I might change or add: goto to boolean functions, replace String if needed and generally try to improve operational speed and reliability.
Thanks for your interest in the program.
