A pin which i don't use works, and i dont know why
i am an Arduino Leonardo user and beginner.
i am using a button and connect it to pin A2
when i click the button, LED works
problem is that
even though i connect the button to other analog pin (for example a3 a4 or a5...) and click the button,
LED works. it must not work
in my code, i don't declare other analog pins. i am using only pin A2
really thank you for reading my question
const int buttonPin = A2; // the number of the pushbutton pin
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
long lastDebounceTime = 0; // the last time the output pin was toggled
const int ledPin = 5; // the number of the LED pin
int ledState = LOW; // the current state of the output pin
long debounceDelay = 30; // the debounce time; increase if the output flickers
pinMode(A2, INPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
int inc = 1;
int bright = 255;
int slideSensor;
void Show_Black() {
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(9, LOW);
void Show_White() {
bright -= 5 * inc;
Serial.println(bright);
analogWrite(5, bright);
analogWrite(6, bright);
analogWrite(9, bright);
if (bright > 254 || bright < 6) {
ledState=LOW;
bright = 255;
if (bright == 5) {
delay(30);
delay(30);
int reading = digitalRead(buttonPin);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == HIGH) {
ledState = !ledState;
if(ledState == HIGH){
Show_White();
else {
Show_Black();
lastButtonState = reading;
Hi, and welcome to the forum.
ssd0023:
To pin A2 and ground?
If so, did you use a pull up resistor.
You could also use the internal pull up resistor of the pin, like this:
pinMode(A2, INPUT_PULLUP);
Leo..
my button is analog touch sensor button.
and i heard INPUT_PULLUP is for digital input, so i dont know if it works or not
anyway, i m gonaa try that thx
You've declared ledState as an int.
What do you expect
to change it to? A bool would be much more appropriate.
if (bright == 5) {
delay(30);
delay(30);
seems rather pointless
INTP /
thank you for giving me a lot of things which i have to revise!!
ssd0023:
Your code:
So you use the pin as a digital input.
And yes, PULLUP also works on analogue pins.
What do you mean with "analogue touch sensor button".
Leo..
Maybe he means capacitive button module
