A problem in a code
Hello everyone I wrote this code and I think there's a problem it says "expected initializer before numeric constant". This code uses force sensor as input data and after 50 presses on it it turn on the light.
int fsrPin = 0;     // the FSR and 10K pulldown are connected to a0
int fsrReading;     // the analog reading from the FSR resistor divider
int led 13
void setup(void) {
  PinMode (led, OUTPUT);
void loop(void) {
  fsrReading = analogRead(fsrPin);
  Serial.print("Analog reading = ");
  Serial.print(fsrReading);     // print the raw analog reading
 Counter=0;
  if (fsrReading >0) {
Counter=Counter+1;
if (x=50){
 digitalWrite (LED,HIGH);
else{
 digitalWrite (LED,LOW);
  else{
Oops
Also oops
And again
Wowser.
got it
how to fix this:
int led 13
didn't understand
and this
With one of these '=' and one of these ';'
With a lower-case p
There is a very high chance for this to be true.
Just a few problems to fix:
const int led = 13;
pinMode(led, OUTPUT);
static int Counter = 0;
if (Counter == 50) {
You called it 'led', not 'LED'.
Does nothing and doesn't fit there. Leave it out.
Missing a '}' at the end.
The last two points
  else{
should I delete it?
but there's '}' by the end should I add one more?
If you don't, you will get an error.
