a problem occurs while uploading the code
I have the problem like this. Could you please give me some pieces of advice?
java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1704)
at java.io.File.createTempFile(File.java:1792)
at processing.app.Base.saveFile(Base.java:1997)
at processing.app.SketchCode.save(SketchCode.java:274)
at processing.app.Sketch.save(Sketch.java:710)
at processing.app.Editor.handleSave2(Editor.java:2129)
at processing.app.Editor$45.run(Editor.java:2117)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Hello, I am having the exact same problem. Did you ever find a solution?
