A problem whit if, I think so
I just started using Arduino and got stuck in a problem.
I'm trying to select a message to display.
I wrote everything in viod setup Just for my convenience, When everything works I want to move it to void loop.
I tried to use int and byte instead of char, but when I check the number it display me the number in Hexadecimal
(49,50,51 etc.) instead of 1,2,3.
I searched here on the site and online and did not find anything that would help me with the problem.
I'm using a mega board.
This is the code I use.
char number=1;
String message1 = "Hey";
String message2 = "Hello";
String message3 = "Whats up";
  Serial.println("Enter a number Between 1-3");
  while (!Serial.available())
  number = Serial.read();
  Serial.print (number); // To check the variable
  if (number == 1) Serial.println (message1);
  if (number == 2) Serial.println (message2);
  if (number == 3) Serial.println (message3);
Sorry if I have grammar issues, English is not my first language.
Thanks for the help,
if i see it right Serial.read doesn't return a "number" but a byte. does it work if you compare it to the characters instead of the literal numbers? does if(number=='1') ... work?
Just subtract ‘0’ from the variable called number.
@frozenrat Yes, it works. Thanks
A '1' from the keyboard is 49, the ASCII value of '1'
One way to fix it would be to subtract the ASCII for '0':
if (number-48 == 1) Serial.println(message1);
if (number-48 == 2) Serial.println(message2);
if (number-48 == 3) Serial.println(message3);
Alternately, subtract ASCII zero when you read the keyboard:
number = Serial.read()-48;
SteveMann:
if we go that path it's always handy to have the ascii chart at hand
It is possible to read the number form serial (not in ascii)?
do you mean like Serial.parseInt?
shvada:
If you don’t send it as ASCII, it won’t be received as ASCII.
That’s hard to do if you’re using the serial monitor.
TheMemberFormerlyKnownAsAWOL:
If you don't send it as ASCII, it won't be received as ASCII.
That's hard to do if you're using the serial monitor.
does the serial monitor support escape characters?
frozenrat:
I do not know this command, I'll see if it works
so how can I make a changing message?
shvada:
I do not know this command, I'll see if it worksso how can I make a changing message?
either you program your own serial monitor / application that talks to your arduino or you use third party software. i chose the first one, no idea what's on the market as third party software.
this thread taught me i want to add binary/hex mode to my serial communication tool :smiley:
