Hello
As a start I'm not a very good programmer, so my code is bit of a mess, but it's working for what I need it to do.
The project is a sensor array for a device to be placed in a parent's bed with their infant sleeping in it. The idea is that the accelerometers will trigger an alarm if a dangerous situation is detected, from a tilt or the device moving around on the bed. Right now that's all working fine, the settings need a bit of fine tuning, but it works. The problem is we'd also like a "night light" that would turn on for a time when a button is pressed, and off after a set time or the button is pressed again.
I've rigged a momentary push button to the no.0 interrupt pin on an Arduino Mega 2560. The code, as I understand it, should stop whatever is running and rung the LIGHT function if the interrupt pin changes between LOW and HIGH, regardless of the direction. I've tried attaching the button to the 5V pin, and to ground and neither way seems to work. I've also confirmed that the button is wired correctly, by just using it as a switch on the LED array when attached to a battery pack.
The interrupt is attached in the setup, and the function it calls is at the end of the code.
Any recommendations would be greatly appreciated, here's the code:
//Pins for Accelerometer 1 set in bridge
const int Pinx1 = 0;
const int Piny1 = 1;
const int Pinz1 = 2;
//Pins for Accelerometer 2 Set in Bridge
const int Pinx2 = 3;
const int Piny2 = 4;
const int Pinz2 = 5;
//Pins for Accelerometer 3 Set in base
const int Pinx3 = 6;
const int Piny3 = 7;
const int Pinz3 = 8;
//Reference values for Accelerometers
int refx1, refx2, refx3, refy1, refy2, refy3, refz1, refz2, refz3;
float grefx1, grefx2, grefx3,grefy1, grefy2, grefy3,grefz1, grefz2, grefz3;
//Read values during operation
float greadx1, greadx2, greadx3,gready1, gready2, gready3,greadz1, greadz2, greadz3;
//Button values
int button1, button2, button3;
//LED Pin
int LEDpin = 13;
void setup ()
//Set startup reference values
grefx1 = analogRead(Pinx1)/102.3*9.81;
grefy1 = analogRead(Piny1)/102.3*9.81;
grefz1 = analogRead(Pinz1)/102.3*9.81;
grefx2 = analogRead(Pinx2)/102.3*9.81;
grefy2 = analogRead(Piny2)/102.3*9.81;
grefz2 = analogRead(Pinz2)/102.3*9.81;
grefx3 = analogRead(Pinx3)/102.3*9.81;
grefy3 = analogRead(Piny3)/102.3*9.81;
grefz3 = analogRead(Pinz3)/102.3*9.81;
Serial.println(grefx1);
Serial.println(grefx2);
Serial.println(grefx3);
Serial.println(grefy1);
Serial.println(grefy2);
Serial.println(grefy3);
Serial.println(grefz1);
Serial.println(grefz2);
Serial.println(grefz3);
//attachInterrupt(0,LIGHT, CHANGE);
int danger=0;
danger = TILT (grefx1,grefx2,grefx3,grefy1,grefy2,grefy3,grefz1,grefz2,grefz3);
Serial.println("danger");
Serial.println(danger);
if (
danger == 1){
ALARM();
danger = DISPLACEMENT ();
if (
danger == 1){
ALARM();
int TILT (float grefx1,float grefx2,float grefx3,float grefy1,float grefy2,float grefy3,float grefz1,float grefz2,float grefz3)
greadx1 = analogRead(Pinx1)/102.3*9.81;
greadx2 = analogRead(Piny1)/102.3*9.81;
greadx3 = analogRead(Pinz1)/102.3*9.81;
gready1 = analogRead(Pinx2)/102.3*9.81;
gready2 = analogRead(Piny2)/102.3*9.81;
gready3 = analogRead(Pinz2)/102.3*9.81;
greadz1 = analogRead(Pinx3)/102.3*9.81;
greadz2 = analogRead(Piny3)/102.3*9.81;
greadz3 = analogRead(Pinz3)/102.3*9.81;
Serial.println(greadx1);
Serial.println(greadx2);
Serial.println(greadx3);
Serial.println(gready1);
Serial.println(gready2);
Serial.println(gready3);
Serial.println(greadz1);
Serial.println(greadz2);
Serial.println(greadz3);
//caculate the sine of half the angle from initial, from direction of gravity
double Theta1 = asin(sqrt((pow((grefx1-greadx1),2) + pow((grefy1-gready1),2) + pow((grefz1-greadz1),2)))/2 / sqrt((pow(grefx1,2) + pow(grefy1,2) + pow(grefz1,2))));
double Theta2 = asin(sqrt((pow((grefx2-greadx2),2) + pow((grefy2-gready2),2) + pow((grefz2-greadz2),2)))/2 / sqrt((pow(grefx2,2) + pow(grefy2,2) + pow(grefz2,2))));
double Theta3 = asin(sqrt((pow((grefx3-greadx3),2) + pow((grefy3-gready3),2) + pow((grefz3-greadz3),2)))/2 / sqrt((pow(grefx3,2) + pow(grefy3,2) + pow(grefz3,2))));
Serial.print("Theta1");
Serial.println(Theta1);
Serial.print("Theta2");
Serial.println(Theta2);
Serial.print("Theta3");
Serial.println(Theta3);
//Note, Safety angle in degrees, initial set to 15
float SafetyAngle = 15*3.14/180;
if (Theta3 >= SafetyAngle/2)
return 1;
else if( Theta2 >= SafetyAngle/2)
return 1;
else if (Theta1 >= SafetyAngle/2)
return 1;
else{
return 0;
int DISPLACEMENT ()
int dispAccelx1[100], dispAccelx2[100], dispAccelx3[100], dispAccely1[100], dispAccely2[100], dispAccely3[100], dispAccelz1[100], dispAccelz2[100], dispAccelz3[100];
float aveAccelx1 =0, aveAccelx2 =0, aveAccelx3 =0, aveAccely1 =0, aveAccely2 =0, aveAccely3 =0, aveAccelz1 =0, aveAccelz2 =0, aveAccelz3 =0;
float drefx1, drefx2, drefx3,drefy1, drefy2, drefy3,drefz1, drefz2, drefz3;
//loop to read 10 samples of acceleration
drefx1 = analogRead(Pinx1)/102.3*9.81;
drefy1 = analogRead(Piny1)/102.3*9.81;
drefz1 = analogRead(Pinz1)/102.3*9.81;
drefx2 = analogRead(Pinx2)/102.3*9.81;
drefy2 = analogRead(Piny2)/102.3*9.81;
drefz2 = analogRead(Pinz2)/102.3*9.81;
drefx3 = analogRead(Pinx3)/102.3*9.81;
drefy3 = analogRead(Piny3)/102.3*9.81;
drefz3 = analogRead(Pinz3)/102.3*9.81;
for (int count = 0; count < 99; count++){
dispAccelx1[count]=analogRead(Pinx1);
dispAccelx2[count]=analogRead(Pinx2);
dispAccelx3[count]=analogRead(Pinx3);
dispAccely1[count]=analogRead(Piny1);
dispAccely2[count]=analogRead(Piny2);
dispAccely3[count]=analogRead(Piny3);
dispAccelz1[count]=analogRead(Pinz1);
dispAccelz2[count]=analogRead(Pinz2);
dispAccelz3[count]=analogRead(Pinz3);
//loop to count the total acceleration
for (int count = 0; count < 99 ; count++){
aveAccelx1 = aveAccelx1 + dispAccelx1[count]/102.3*9.81;
aveAccely1 = aveAccely1 + dispAccely1[count]/102.3*9.81;
aveAccelz1 = aveAccelz1 + dispAccelz1[count]/102.3*9.81;
aveAccelx2 = aveAccelx2 + dispAccelx2[count]/102.3*9.81;
aveAccely2 = aveAccely2 + dispAccely2[count]/102.3*9.81;
aveAccelz2 = aveAccelz2 + dispAccelz2[count]/102.3*9.81;
aveAccelx3 = aveAccelx3 + dispAccelx3[count]/102.3*9.81;
aveAccely3 = aveAccely3 + dispAccely3[count]/102.3*9.81;
aveAccelz3 = aveAccelz3 + dispAccelz3[count]/102.3*9.81;
//determining the average acceleration
aveAccelx1 = aveAccelx1/100;
aveAccelx2 = aveAccelx2/100;
aveAccelx3 = aveAccelx3/100;
aveAccely1 = aveAccely1/100;
aveAccely2 = aveAccely2/100;
aveAccely3 = aveAccely3/100;
aveAccelz1 = aveAccelz1/100;
aveAccelz2 = aveAccelz2/100;
aveAccelz3 = aveAccelz3/100;
//Net accelration (loses direction in this eqn.)
float netAccel1 = sqrt((pow(aveAccelx1-drefx1,2) + pow(aveAccely1-drefy1,2) + pow(aveAccelz1-drefz1,2)));
float netAccel2 = sqrt((pow(aveAccelx2-drefx2,2) + pow(aveAccely2-drefy2,2) + pow(aveAccelz2-drefz2,2)));
float netAccel3 = sqrt((pow(aveAccelx3-drefx3,2) + pow(aveAccely3-drefy3,2) + pow(aveAccelz3-drefz3,2)));
//estimate of read time, based on .0001 sec per read
float time = .09;
//displacement based on 0 initial velocity
float disp1 = .5 * netAccel1 * pow(time,2);
float disp2 = .5 * netAccel2 * pow(time,2);
float disp3 = .5 * netAccel3 * pow(time,2);
Serial.println(disp1);
Serial.println(disp2);
Serial.println(disp3);
if ( disp3 >= .3)
return 1;
else if (abs(disp1-disp3) >= .01)
return 1;
else if(abs(disp2-disp3) >= .01)
return 1;
else{
return 0;
void ALARM ()
int Buzzer = 12;
while (1)
analogWrite(LEDpin, 153);
analogWrite(Buzzer, 255);
analogWrite(LEDpin, 0);
analogWrite(Buzzer, 0);
void LIGHT ()
Serial.println("light");
delay(300000);
return;
