I use Arduino as a data recorder for measuring the pulse rate , and i want to show the signal on processing software , but there are many errors that i didn't recognize them . these errors are :
serial does not run in 64-bit mode.
processing.app.SketchException: serial is only compatible with the 32-bit download of Processing.
at processing.mode.java.runner.Runner.(Runner.java:108)
at processing.mode.java.JavaMode.handleRun(JavaMode.java:122)
at processing.mode.java.JavaEditor$20.run(JavaEditor.java:480)
at java.lang.Thread.run(Thread.java:662)
and this ones are in Arduino sofware :
processing.app.SerialException: Serial port 'COM7' already in use. Try quiting any programs that may be using it.
at processing.app.Serial.(Serial.java:171)
at processing.app.Serial.(Serial.java:92)
at processing.app.SerialMonitor.openSerialPort(SerialMonitor.java:207)
at processing.app.Editor.handleSerial(Editor.java:2481)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:353)
at java.awt.Component.processMouseEvent(Component.java:6260)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4235)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2475)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
at processing.app.Editor$17.actionPerformed(Editor.java:665)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.AbstractButton.doClick(AbstractButton.java:337)
at javax.swing.plaf.basic.BasicMenuItemUI$Actions.actionPerformed(BasicMenuItemUI.java:1194)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1636)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2851)
at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:670)
at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:678)
at javax.swing.JMenuBar.processKeyBinding(JMenuBar.java:649)
at javax.swing.KeyboardManager.fireBinding(KeyboardManager.java:267)
at javax.swing.KeyboardManager.fireKeyboardAction(KeyboardManager.java:254)
at javax.swing.JComponent.processKeyBindingsForAllComponents(JComponent.java:2928)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2920)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2814)
at java.awt.Component.processEvent(Component.java:6040)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1848)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:704)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:969)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:841)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:668)
at java.awt.Component.dispatchEventImpl(Component.java:4502)
The question is , what is exactly the problem ? and how to fix it ?
