A problem with Seven Segment.. Help me !!! Plz
Hi All,
I'm a beginner in programming so please explain in easy words.
My project is to send a unique code from sender(Nano) to receiver (Uno) to display sender's number via wireless connection(HC-12)
Used 7 Segment 4 digit
It is similar to wireless calling system, broadly used in restaurant, hospital
Problem is when I press the button on the sender, it only shows by each segment.
Here it is my code for sender
SoftwareSerial mySerial(2, 3); //RX, TX
int buttonPin = 8;
boolean onOff = 0; //I have no idea what it does but seems working well
pinMode(buttonPin, INPUT);
mySerial.begin(9600);
int buttonState = digitalRead(buttonPin);//read button state
if(buttonState == 1){
mySerial.println(1234); { //send unique code to the receiver to turn on.
onOff = 1;//set boolean to 1
delay(100);
Receiver code
#include "SevSeg.h"
#include <SoftwareSerial.h>
SevSeg sevseg; //Initiate a seven segment controller object
SoftwareSerial mySerial(0,1); // RX, TX
byte numDigits = 4;
byte digitPins[] = {2, 3, 4, 5};
byte segmentPins[] = {6, 7, 8, 9, 10, 11, 12, 13};
sevseg.begin(COMMON_CATHODE, numDigits, digitPins, segmentPins);
sevseg.setBrightness(90);
if(mySerial.available() > 1){
int input = mySerial.parseInt();//read serial input and convert to integer (-32,768 to 32,767)
if(input == 1234){ //**Want to add some time to display number until other code is receive **
sevseg.setNumber(4);
sevseg.refreshDisplay();
delay(100);
if(input == 5678){//if on code is received
sevseg.setNumber(5);
delay(100);
mySerial.flush();
delay(10);
Thank you all in advance :slight_smile:
ckor01:
could you explain the problem a bit more please... to me your the problem is unclear
did you try to print out to serialmonitor 'input' at the receiver to see if you received correctly your sender id?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks... Tom.. :slight_smile:
Well, if you are getting anything at all to display on the seven segment devices, that is a good start.
Without looking at it too deeply, I suggest first to change this on the RX side:
SoftwareSerial mySerial(0,1); // RX, TX   // DON'T USE 0 or 1 for software serial
Once you have done that, and changed the wiring to match, you can use Serial.begin() and Serial.print() to print debug messages, for example the contents of your variable input.
1st, you should check if transmission is working OK.
2nd, check if pins are defined and connected correctly on sevseg library. You can make a simple program on that microcontroller to check if it displays your desired numbers. Oh, also nothe that you may need to call SevSeg::refreshDisplay() on loop!
3rd, you may try other libraries, as this one I developed and is now on Arduino IDE Library Manager: GitHub - Naguissa/uSevenSegmentLib: Arduino, ESP8266 and STM32 7-segment multiplexed displays library - uSevenSegmentLib
(also intall uTimerLib, needed to work and also available on Library Manager).
/// test 7 segment display then delete / comment out
{ // test code block
sevseg.setNumber(4); // does display shows digit 4 ? where - MSD or LSD?
sevseg.refreshDisplay(); /// may need this here, just once
while(1); // just temporary loop to show display is working
} // test code block
this will execute AFTER there are 2 or more data in mySerial.buffer
//temporary copy AFTER loop () starts - see above TEST 7 segment display
delay(100);
// in practice you could use else if since you have only two choises
// else if( input == 5678)
delay(100);
// perhaps display something here as an indicator that both above "ifs" failed
// maybe your library can display characters, like this ?
sevseg.setNumber("0000"); // or "----" ??
mySerial.flush(); // awaits for Serial output to complete - why?
delay(10);
