A question about nrf240l
heyy
I have a Project to connect a 1 master 2 slaves nrf boards to get sensor values from the two slaves to the master board
It working with the first slave but with the second dosn't work
any help!
master code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Wire.h>
const int pinButton = 8;
const uint64_t pipeOut = {00};
const uint64_t pipeIn = {01};
const uint64_t pipeIn2 = {02};
RF24 radio(10, 9);
RF24 network(radio);
struct MyData {
 float re;
 float h;
 float t;
 float f;
 float v;
 float ds;
 float h2;
 float t2;
 float ds2;
MyData data;
  pinMode(pinButton, INPUT);
 radio.begin();
 radio.setAutoAck(false);
 radio.setDataRate(RF24_250KBPS);
   radio.openReadingPipe(1, pipeIn);
   radio.openReadingPipe(2, pipeIn);
 radio.openWritingPipe(pipeOut);
   radio.startListening();
 if ( radio.available() ) {
   radio.read(&data, sizeof(MyData));
   Serial.print("relay: ");
   Serial.print(data.re);
   Serial.println(" " );
   Serial.print("Humidity: " );
   Serial.print(data.h);
   Serial.print("Temperature: ");
   Serial.print(data.t);
   Serial.print("flow rate: ");
   Serial.print(data.f);
   Serial.print("volume: ");
   Serial.print(data.v);
   Serial.print("external temp: ");
   Serial.print(data.ds);
   Serial.print("external temp 2: ");
   Serial.print(data.ds2);
   Serial.print("Humidity 2: " );
   Serial.print(data.h2);
   Serial.print("Temperature 2: ");
   Serial.print(data.t2);
   delay (5000);
slave code
LiquidCrystal_I2C lcd(0x27,20,4);
#include <SPI.h>
#include <RF24.h>
#include <Wire.h>
int dataToSend = 6;
#include "DHT.h"
const byte address[5] = "00001";
const uint64_t pipeIn = 00;
const uint64_t pipeOut = 01;
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 4
#define DHTTYPE    DHT11
DHT_Unified dht(DHTPIN, DHTTYPE);
uint32_t delayMS;
#include <DS18B20.h>
DS18B20 ds(3);
#include <FlowMeter.h>
FlowMeter Meter = FlowMeter(2);
const unsigned long period = 1000;
void MeterISR() {
   Meter.count();
RF24 radio(10, 9); //  CN and CSN  pins of nrf
struct MyData {
 float re;
 float h;
 float t;
 float f;
 float v;
 float ds;
MyData data;
lcd.init();
 lcd.backlight();
 Serial.print("Devices: ");
 Serial.println(ds.getNumberOfDevices());
 dht.begin();
 sensor_t sensor;
 dht.temperature().getSensor(&sensor);
 Serial.println(F("------------------------------------"));
 Serial.println(F("Temperature Sensor"));
 Serial.print  (F("Sensor Type: ")); Serial.println(sensor.name);
 Serial.print  (F("Driver Ver:  ")); Serial.println(sensor.version);
 Serial.print  (F("Unique ID:   ")); Serial.println(sensor.sensor_id);
 Serial.print  (F("Max Value:   ")); Serial.print(sensor.max_value); Serial.println(F("°C"));
 Serial.print  (F("Min Value:   ")); Serial.print(sensor.min_value); Serial.println(F("°C"));
 Serial.print  (F("Resolution:  ")); Serial.print(sensor.resolution); Serial.println(F("°C"));
 dht.humidity().getSensor(&sensor);
 Serial.println(F("Humidity Sensor"));
 Serial.print  (F("Max Value:   ")); Serial.print(sensor.max_value); Serial.println(F("%"));
 Serial.print  (F("Min Value:   ")); Serial.print(sensor.min_value); Serial.println(F("%"));
 Serial.print  (F("Resolution:  ")); Serial.print(sensor.resolution); Serial.println(F("%"));
 if (isnan(data.h) || isnan(data.t)){
     Serial.println(F("Failed to read from DHT sensor!"));
     return;
 delayMS = sensor.min_delay / 1000;
 attachInterrupt(INT0, MeterISR, RISING);
 Meter.reset();
 radio.begin();
 radio.stopListening();
 //lcd.println("Receiver ");
 while (ds.selectNext()) {
   switch (ds.getFamilyCode()) {
     case MODEL_DS18S20:
       Serial.println("Model: DS18S20/DS1820");
     case MODEL_DS1822:
       Serial.println("Model: DS1822");
     case MODEL_DS18B20:
       Serial.println("Mode2: DS18B20");
     default:
       Serial.println("Unrecognized Device");
   uint8_t address[8];
   ds.getAddress(address);
   Serial.print("Address:");
   for (uint8_t i = 0; i < 8; i++) {
     Serial.print(" ");
     Serial.print(address[i]);
   Serial.print("Resolution: ");
   Serial.println(ds.getResolution());
   Serial.print("Power Mode: ");
   if (ds.getPowerMode()) {
     Serial.println("External");
     Serial.println("Parasite");
   Serial.print(ds.getTempC());
   data.ds = ds.getTempC();
   Serial.print(" C / ");
   lcd.setCursor(0,2);
   lcd.print(ds.getTempC());
   lcd.setCursor(6,2);
   lcd.print("C");
 delay(2000);
 delay(delayMS);
 sensors_event_t event;
 dht.temperature().getEvent(&event);
 if (isnan(event.temperature)) {
   Serial.println(F("Error reading temperature!"));
   lcd.setCursor(3,0);
 lcd.print(F("Error reading temperature!"));
 else {
   Serial.print(F("Temperature: "));
   Serial.print(event.temperature);
   lcd.setCursor(0,0);
   lcd.print(F("Temp:"));
   lcd.print(event.temperature);
    data.t = event.temperature;
   lcd.print(F("°C"));
 dht.humidity().getEvent(&event);
 if (isnan(event.relative_humidity)) {
   Serial.println(F("Error reading humidity!"));
 else {
   Serial.print(F("Humi:"));
   Serial.print(event.relative_humidity);
   lcd.setCursor(0,1);
   lcd.print(F("Humidity: "));
   lcd.print(event.relative_humidity);
   data.h = event.relative_humidity;
   lcd.print(F("%"));
   delay(period);
   Meter.tick(period);
   Serial.println("Currently " + String(Meter.getCurrentFlowrate()));
    data.f = Meter.getCurrentFlowrate();
   Serial.println ( " l/min, " + String(Meter.getTotalVolume()));
    data.v = Meter.getTotalVolume();
   Serial.println (" l total.");
   lcd.setCursor(0,3);
   lcd.print("Currently " + String(Meter.getCurrentFlowrate()));
  radio.write(&data, sizeof(MyData));
   radio.write( &dataToSend, sizeof(dataToSend) );
   data.re = digitalRead(pinButton);
Is slave two writing on a different pipe?
no
#include <SPI.h>
#include <RF24.h>
#include <Wire.h>
int dataToSend = 6;
#include "DHT.h"
const uint64_t pipeIn = {00};
const uint64_t pipeOut = {02};
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 4
uint32_t delayMS;
DS18B20 ds(3);
struct MyData {
 float h2;
 float t2;
 float ds2;
MyData data;
lcd.init();
 lcd.backlight();
 dht.begin();
 sensor_t sensor;
 if (isnan(data.h2) || isnan(data.t2)){
     return;
 radio.begin();
     case MODEL_DS18S20:
     case MODEL_DS1822:
     case MODEL_DS18B20:
     default:
   uint8_t address[8];
     Serial.print(" ");
   data.ds2 = ds.getTempC();
   lcd.setCursor(0,2);
   lcd.setCursor(6,2);
   lcd.print("C");
 delay(2000);
 delay(delayMS);
   lcd.setCursor(3,0);
 else {
   lcd.setCursor(0,0);
    data.t2 = event.temperature;
   lcd.print(F("°C"));
 else {
   lcd.setCursor(0,1);
   data.h2 = event.relative_humidity;
   lcd.print(F("%"));
Please use the code tag button, </> on the menu, next time you post your code.
Thank you.
Moderator.
Have a look at this Simple nRF24L01+ Tutorial.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
The Tutorial includes an example for a master and 2 slaves that can easily be extended to a larger number of slaves.
...R
