A question to change the sample rate in MPU6050.h file
Dear all,
I am working on a small project and need to have the sample rate up to 50Hz. I ran to a thread in Arduino Forum community and someone said that he was able to change a setting from 0x0A to 0x03 in MPU6050.h (Jeff’s MPU6050 raw code) to have the sample rate moved up from 18Hz to 50Hz. I am not able to locate that line of code in mpu6050.h file. You can click the link to see the file. (i2cdevlib/MPU6050.h at master · jrowberg/i2cdevlib · GitHub) I am currently using your MPU6050 raw code. It works great for me. The thread is here.
http://forum.arduino.cc/index.php?topic=109441.0;wap2
Thank you all.
Ji
Call the setRate() method perhaps?
Thanks, Mark.
How should I call the setRate()? Sorry, I am a very rookie that doesnt have any experiencing in actual coding. Do I first need to find the setRate() in the MPU6050.h file? Thanks again.
Anybody have ideas about how to do this? Thanks ahead.
There is a sticky at the top of the forum that discusses how to ask a question on the forum. On this forum, you need to post your code.
At least defining what a MPU6050 is would be helpful. You have one, so you know what it is. When YOU are asking for help, why do you expect us to google it?
Have you even looked at the library to see what that function does? What it's default value is?
Hi Paul,
Sorry for such an inconvenience. I tried to post the code in my original message. But the forum didn’t allow me to upload it and warned me that the code was too long. That is why I chose an alternative to attach a link here. This link is right into the MPU6050.h code.
A little details about MPU6050: it is a triaxial accelerometer/gyro sensoing platform and is released from Sparkfun. https://www.sparkfun.com/products/11028
Here I attach the whole package of execution codes here for my project. This project uses Arduino ProMini 328 3.3V/8MHz to read data from MPU6050. Arduino ProMini is connected to my laptop which uses serial monitor to track the data input from MPU6050.
The running code is MPU6050_raw_1.ino. The embedded code for MPU6050 chip is MPU6050.cpp and MPU6050.h. And the rest of them are embedded codes for I2C bus.
Sorry I am really new to programming. I would apologize again for any ignorance and inconvenience my actions have caused along the way.
Ji
MPU6050_raw_1.zip (44.2 KB)
