A question
Hello,
First off all, i'm new here so bare with me :wink:
I have this question;
I am working on a fully automated temperature control for my snakes.
I decided to work with Arduino Uno as it is fairy simple to understand compared to
other modules on the market.
Now i was wondering if it's possible, to read the temp values with vb.net, and write to
arduino if needed to activate the relays.
An example would be geat!!
Thanks in advance!
Boredtc
Yes, it's possible. A popular choice of temperature sensor is the DS18B20. Here's a link to a tutorial on using it: Using a DS18B20 Temperature sensor with an Arduino- ar3ne1tt. The arduino can take care of reading the temp and use a relay to turn a heater on. There's no particular need to run anything on a PC unless you want to log the heating activity.
Yes, it is.
There are examples posted almost daily. YOU need to spend some time searching. The Arduino and the PC are going to communicate via the serial port, if you need a keyword clue.
boredtc:
bare with me
If you insist, but I hardly know you.
Hey,
After I've done some homework, i found out how.
Thanks for sharing!
One last question, maybe some of you are familiar with this issue;
I made my Arduino funcion as a Thermostat.
The temp readings works good untill the relays switches, the temperature remains
above normal after the coil is powered.
Is this because the relays consumes too much power for the temp-sensor to remain accurate?
Both components are wired to the 5v arduino pin.
Thanks in advance, and my appologies in advance for bad english :smiley:
Can be, can also be a SW bug.
Please post your code
  • a drawing of your schematic
  • the spec of your relay.
Then we can think with you .
First my code;
int temperaturePin = 0;
int klik = 2;
  pinMode (klik, OUTPUT);
 float temperature = getVoltage(temperaturePin);
 temperature = (temperature - .5) * 100;
 Serial.println(temperature);
if (temperature > 24.00)
    digitalWrite (klik, HIGH);
  else if ((temperature < 24.00))
    digitalWrite (klik, LOW);
float getVoltage(int pin){
 return (analogRead(pin) * .004882814);
The scematic is the one provided by sparklefun ( circ-11)
I've just added an temp-sensor to the 5V, ground and anolog pin 0.
I'm not that good in drawing scematics haha, sorry.
Thanks in advance. (bedankt ;))
