A Safe with LCD,2 leds green and red, 1 microswitch(optional)2 servo,fingerprint
Okay Guys i need help with a code for my project i have and lcd,and servo that works,now the 2leds,microswitch and fingerprint i cant get to work.
i need help i do not understand very much of programming im trying to learn a bit by bit,and sorry for my english.
here is my code this code works with lcd and 2 servos now i need is microswitch to work with the 2 leds when it detects the door and fingerprint this is all i need. Ty
#include <Servo.h>;
const int servoPin1 = 13;
const int servoPin2 = 12;
Servo servo1;
Servo servo2;
int counter = 0;
#include <Keypad.h>
const byte numRows = 4; //number of rows on the keypad
const byte numCols = 4; //number of columns on the keypad
int PIN_CODE[4] = {2, 5, 8, 0};
int PIN_INTRO[4];
int flag = 0;
int ERRO = 0;
/*keymap defines the key pressed according to the row and columns just as appears on the keypad*/
char keymap[numRows][numCols] =
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {11, 10, 9, 8}; //Rows 0 to 3
byte colPins[numCols] = {7, 6, 5, 4}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad = Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
#include <Wire.h>
// Inicializa o display no endereco 0x27
LiquidCrystal_I2C lcd(0x3f, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
PIN_CODE[0] = '2';
PIN_CODE[1] = '5';
PIN_CODE[2] = '8';
PIN_CODE[3] = '0';
lcd.begin (16, 2);
lcd.setBacklight(HIGH);
lcd.setCursor(0, 0);
lcd.print("Arduino 12TGEI");
lcd.setCursor(0, 1);
lcd.print("LCD e modulo I2C");
pinMode( 2 , INPUT );
servo1.attach (servoPin1);
servo2.attach (servoPin2);
servo1.write (80);
servo2.write (150);
//If key is pressed, this key is stored in keypressed variable
//If key is not equal to NO_KEY, then this key is printed out
//if count=17, then count is reset back to 0 (this means no key is pressed during the whole keypad scan process
int keypressed = myKeypad.getKey();
if (keypressed != NO_KEY)
  Serial.println(keypressed);
  Serial.println(flag);
  if (flag < 4) {
    if (flag == 0) {
      lcd.print(" INTRODUZIR PIN ");
      lcd.print("                 ");
      lcd.setCursor(1, 1);
    lcd.print("  *");
    PIN_INTRO[flag] = keypressed;
    Serial.print("flag = ");
    Serial.print("PIN_INTRO["); Serial.print(flag); Serial.print("]="); Serial.println(PIN_INTRO[flag]);
    Serial.print("PIN_CODE["); Serial.print(flag); Serial.print("]="); Serial.println(PIN_CODE[flag]);
    flag++;
  if (flag == 4) {
    valida();
    flag = 0;
void valida()
ERRO = 0;
for (int i = 0; i < 4; i++) {
  if (PIN_INTRO[i] != PIN_CODE[i]) {
    Serial.print("PIN_INTRO["); Serial.print(i); Serial.print("]="); Serial.println(PIN_INTRO[i]);
    Serial.print("PIN_CODE["); Serial.print(i); Serial.print("]="); Serial.println(PIN_CODE[i]);
    ERRO++;
Serial.print("ERRO = ");
Serial.println(ERRO);
if (ERRO == 0) {
  lcd.print("   PIN CORRETO ");
  lcd.print("   ABRIR PORTA  ");
  servo1.write (80);
  servo2.write (150);
  delay(2000);
  lcd.print("                ");
  lcd.print("   PIN ERRADO  ");
  lcd.print("                ");
  servo1.write (150);
  servo2.write (75);
  delay(2000);
  lcd.print("                ");
flag = 0;
OK, first things first.
You need to go and read the forum instructions so that you can go back and modify your original post (not re-post it) - using the “More → Modify” option below the right hand corner of your post - to mark up your code as such using the “</>” icon in the posting window. Just highlight each section of code (or output if you need to post that) from the IDE and click the icon.
In fact, the IDE has a “copy for forum” link to put these markings on a highlighted block for you so you then just paste it here in a posting window. But even before doing that, don’t forget to use the “Auto-Format” (Ctrl-T) option first to make it easy to read. If you do not post it as “code” it has as you now see, become garbled and is always more difficult to read.
It is inappropriate to attach it as a “.ino” file unless it is clearly too long to include in the post proper. People can usually see the mistakes directly and do not want to have to actually load it in their own IDE. And that would also assume they are using a PC and have the IDE running on that PC.
Also tidy up your blank space. Do use blank lines, but only between complete functional blocks.
