hi everyone . i have a simple question . i need a sensor or an idea for detect how far a human is moved . let me explain it :
i want to know how far i am walked
so why i'm not using google maps ???
Because it is not accurate, especially at indoor places
I need an accuracy of about 4 to 20 inches (10 to 50 cm)
I do not know exactly what to do. I know I can not use UltraSonic. So what should I do?
Use a mouse sensor? Problem with taking steps
Use wheels on shoes? I think it is stupid
Do you have an idea / know a specific sensor?
Outdoors, GPS works, but is not that accurate. Indoors, the problem is called "indoor localization", and it is a hard one.
Pozyx works indoors, but is expensive. https://www.pozyx.io/
How far have you moved if you walk up stairs or down stairs?
srnet
January 11, 2022, 7:23am
6
When you state the 'accuracy' like that you probably know what you mean, but the forum does not.
For instance does your project require that you know how far a human has moved in a full day to an 'accuracy' of 10cm ?
What is the actual application ? If you reveal that its possible the forum will know of possible solutions.
Bro don't complicate it . This is for school competition
It does not matter. I mean a simple walk
tmmsnec
January 11, 2022, 2:26pm
10
Consider a simple walk. I mean how much a person is moved by walking. 50 cm by 10 meters.
There must be a simple way to measure it
MrMark
January 11, 2022, 2:33pm
11
There doesn't have to be a simple answer to every problem.
To better constrain the problem, it might be helpful if you give a higher level overview of what you're trying to accomplish. You're estimating displacement, but over what time period, in what environment (how big a space), and what bad things happen if the system fails to perform as expected?
Another technology that may be applicable are a footpod accelerometers.
tmmsnec:
Pick up a pedometer at the local variety store. Less than $10.
WiFi may, or may not, exist?
Also, WPS (WiFi Protected Setup) - that's not at all confusing, is it?
Yea, The WiFi access points may not exist, perhaps an area can be ringed with WIFi or if near the right location a WAAS receiver could be used to get LOP. And there is GEONS, GPS-Enhanced Onboard Navigation System (GEONS) | T2 Portal (nasa.gov) but that is going to cost.
tmmsnec
January 12, 2022, 6:17pm
15
MrMark:
a simple walking for blinds (and system is a walking guide !) . and if system fails , they will ran into a tree or ...
hmm... I will definitely try it, If it was available in my country
thank you for your help !
Will that be able to identify when the person walks backward or forward or turns in place?
tmmsnec
January 12, 2022, 6:21pm
17
jremington:
pedometer
i'll research and try it. hope it works
tmmsnec
January 12, 2022, 6:23pm
18
gps, wifi, glonass and .... They are all useless for me
Could you say a bit more about why?
tmmsnec
January 12, 2022, 6:36pm
20
for school competitions .
