When using LoRa, I have tried to program 2 sensors, which must send the data to the receiver, however when sending the data the sensors do not work.
The sensors used are: BME280 and CCS811
This code is in which when sending the data, the sensors stop working:
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//Libraries for BME280
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
//Libraries for CCS811
#include "Adafruit_CCS811.h"
Adafruit_CCS811 ccs;
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
#define BAND 866E6
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
TwoWire I2Cone = TwoWire(1);
Adafruit_BME280 bme;
//packet counter
int readingID = 0;
int counter = 0;
String LoRaMessage = "";
float temperature = 0;
float humidity = 0;
float pressure = 0;
float co2 = 0;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
//Initialize OLED display
void startOLED() {
//reset OLED display via software
pinMode(OLED_RST, OUTPUT);
digitalWrite(OLED_RST, LOW);
delay(20);
digitalWrite(OLED_RST, HIGH);
//initialize OLED
Wire.begin(OLED_SDA, OLED_SCL);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.clearDisplay();
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(0, 0);
display.print("LORA SENDER");
//Initialize LoRa module
void startLoRA() {
//SPI LoRa pins
SPI.begin(SCK, MISO, MOSI, SS);
//setup LoRa transceiver module
LoRa.setPins(SS, RST, DIO0);
while (!LoRa.begin(BAND) && counter < 10) {
Serial.print(".");
counter++;
if (counter == 10) {
// Increment readingID on every new reading
readingID++;
Serial.println("Starting LoRa failed!");
Serial.println("LoRa Initialization OK!");
display.setCursor(0, 10);
display.print("LoRa Initializing OK!");
display.display();
delay(2000);
void startSensors() {
I2Cone.begin(SDA, SCL, 100000);
bool status1 = bme.begin(0x76, &I2Cone);
if (!status1) {
Serial.println("Could not find a valid BME280_1 sensor, check wiring!");
while (1);
Serial.println("CO2, TVOC");
if (!ccs.begin()) { // Intentar inicializar el sensor
Serial.println("¡No se ha podido inicializar el sensor! Por favor, comprueba el cableado.");
while (1);
while (!ccs.available()); // Esperar a que el sensor esté preparado
void getReadings() {
co2 = ccs.geteCO2(); // Obtener y enviar el nivel del CO2 por el puerto serie
temperature = bme.readTemperature();
humidity = bme.readHumidity();
pressure = bme.readPressure() / 100.0F;
void sendReadings() {
LoRaMessage = String(readingID) + "/" + String(temperature) + "&" + String(humidity) + "#" + String(pressure);
//Send LoRa packet to receiver
LoRa.beginPacket();
LoRa.print(LoRaMessage);
LoRa.endPacket();
display.print("CO2:");
display.setCursor(72, 0);
display.print(co2);
display.setCursor(0, 20);
display.print("Temperature:");
display.setCursor(72, 20);
display.print(temperature);
display.setCursor(0, 30);
display.print("Humidity:");
display.setCursor(54, 30);
display.print(humidity);
display.setCursor(0, 40);
display.print("Pressure:");
display.setCursor(54, 40);
display.print(pressure);
display.setCursor(0, 50);
display.print("Reading ID:");
display.setCursor(66, 50);
display.print(readingID);
display.display();
Serial.print("Sending packet: ");
Serial.println(readingID);
readingID++;
//initialize Serial Monitor
startOLED();
startSensors();
startLoRA();
delay(2000);
Serial.print("MIERDA");
if (ccs.available()) { // Si el sensor está disponible
if (!ccs.readData()) {
getReadings();
sendReadings();
This code is without sending data, in which the sensors do work:
float humidity = 0;
float pressure = 0;
float co2 = 0;
if (!status1) {
while (1);
while (1);
if (!ccs.readData()) { // Cuando haya datos
Serial.print("CO2:");
Serial.println(co2);
Serial.print("Temp:");
Serial.println(temperature);
Serial.print("Hum:");
Serial.println(humidity);
Serial.print("Press:");
Serial.println(pressure);
else {
Serial.println("ERROR!"); // Cuando ocurra un error
while (1); // El dispositivo deja de funcionar
delay(2000); // Hacer la medida cada 2 segundos(2000ms)
Here the circuit:
