A sensor to weigh very small weights
I would like to build an Ardrino unit to accurately measure small weights, specifically bullet reloading components such as projectiles and gunpowder.
So in the first instance as a learning thing I want to detect what is known as a squib round. So the completed round of ammunition weighs about 300grains (1 grain = 0.0647 grammes) or about 20 grammes. If the loaded round is a "squib" it will be missing the 45grains of gunpowder so only weigh 255grains (16.5grammes) I have been looking for a sensor to use for this to no avail, any ideas please?
In the second job I want to be able to dump 1000 projectiles into a hopper and have the ardrino separate them out by weight into batches. The nominal weight would be anything from 50grains to 230grains. (3grammes to 16 grammes). It maybe I need a second, finer sensor for this job.
gzcwnk: I would like to build an Ardrino unit to accurately measure small weights, specifically bullet reloading components such as projectiles and gunpowder.
Tried google much? There's lots of information about similar projects. This 20 gram x 0.001 gram scale ought to meet the weight requirements for your first "job." (No Arduino required for the first "job," far as I can tell from your post.)
And you could hack that scale for your second "job." I did that with their 200 g scale - wasn't too hard to do. This 20 g scale would be more physically "delicate" and subject to damage from accidental rough handling or whatever.
What's your experience with building this sort of thing?
That will probably take some mechanical engineering skills. How do you imagine this working?
A lot of digital balances have serial ports.
I have two balances which have RS232 serial ports. It's pretty easy to convert the RS232 signal to a microcontroller friendly signal. A MAX232 can be used to go from RS232 to a 5V logic and a MAX3232 can be used for 3.3V logic devices.
jremington: That will probably take some mechanical engineering skills. How do you imagine this working?
Probably like this. A bit larger if he's weighting lead bullets though.
