Hey everybody.
I am still working on getting my STP16DP05B1R's to play well with my Arduino. For some background: I developed a little project to run 200 LEDs in a chain from my Arduino using shift registers. Things are going pretty well, and I can chain them together just fine. The LEDs react pretty much the way I want them to (to data coming in from Processing). I am just running into a bizarre problem. It would seem that I can drive 8 LEDs from each register (pins 0-7) but there is no activity on pins 8-15.
I checked the output voltage on each pin, and it looks like pins 0-7 are outputting variating positive voltage, but I am getting variating negative readings from 8-15. Is that normal? Can anybody shine a little light on that one for me?
At this point, I'm sure that I'm just missing something stupid, but I've been staring at this thing for so long that I figure a fresh set of eyes might just do the trick. It's likely quite simple. Please bear in my that I don't really know much about programming, but I am deeply interested in learning -- most of this has been brute force trial and error.
Let's take a look. The comments from the ShiftOut tutorial have been left intact for the most part, for clarity.
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
//holders for infromation you're going to pass to shifting function
byte data1;
byte data2;
byte data3;
byte data4;
byte data5;
byte data6;
byte data7;
byte data8;
byte data9;
byte data10;
byte data11;
byte data12;
byte dataArray1[16];
byte dataArray2[16];
byte dataArray3[16];
byte dataArray4[16];
byte dataArray5[16];
byte dataArray6[16];
byte dataArray7[16];
byte dataArray8[16];
byte dataArray9[16];
byte dataArray10[16];
byte dataArray11[16];
byte dataArray12[16];
int amp;
pinMode(latchPin, OUTPUT);
// chip 1 Array
//Arduino doesn't seem to have a way to write binary straight into the code
//so these values are in HEX. Decimal would have been fine, too.
dataArray1[0] = 0xFFFF; //1111111111111111
dataArray1[1] = 0xFFFE; //1111111111111110
dataArray1[2] = 0xFFFC; //1111111111111100
dataArray1[3] = 0xFFF8; //1111111111111000
dataArray1[4] = 0xFFF0; //1111111111110000
dataArray1[5] = 0xFFE0; //1111111111100000
dataArray1[6] = 0xFFC0; //1111111111000000
dataArray1[7] = 0xFF80; //1111111110000000
dataArray1[8] = 0xFF00; //1111111100000000
dataArray1[9] = 0xFE00; //1111111000000000
dataArray1[10] = 0xF800; //1111100000000000
dataArray1[11] = 0xF000; //1111000000000000
dataArray1[12] = 0xE000; //1110000000000000
dataArray1[13] = 0xC000; //1100000000000000
dataArray1[14] = 0x8000; //1000000000000000
dataArray1[15] = 0x0000; //0000000000000000
// chip 2 Array
dataArray2[16] = 0xFFFF; //1111111111111111
dataArray2[17] = 0xFFFE; //1111111111111110
dataArray2[18] = 0xFFFC; //1111111111111100
dataArray2[19] = 0xFFF8; //1111111111111000
dataArray2[20] = 0xFFF0; //1111111111110000
dataArray2[21] = 0xFFE0; //1111111111100000
dataArray2[22] = 0xFFC0; //1111111111000000
dataArray2[23] = 0xFF80; //1111111110000000
dataArray2[24] = 0xFF00; //1111111100000000
dataArray2[25] = 0xFE00; //1111111000000000
dataArray2[26] = 0xF800; //1111100000000000
dataArray2[27] = 0xF000; //1111000000000000
dataArray2[28] = 0xE000; //1110000000000000
dataArray2[29] = 0xC000; //1100000000000000
dataArray2[30] = 0x8000; //1000000000000000
dataArray2[31] = 0x0000; //0000000000000000
// truncated for space
if (Serial.available()) { // begin LED drive code
amp = Serial.read();
//load the light sequence you want from array
if (amp <= 15){
data1 = dataArray1[amp];
data2 = dataArray2[31];
data3 = dataArray3[47];
data4 = dataArray4[63];
data5 = dataArray5[79];
data6 = dataArray6[95];
data7 = dataArray7[111];
data8 = dataArray8[127];
data9 = dataArray9[143];
data10 = dataArray10[159];
data11 = dataArray11[175];
data12 = dataArray12[191];
//ground latchPin and hold low for as long as you are transmitting
digitalWrite(latchPin, 0);
//move 'em out
shiftOut(dataPin, clockPin, data12);
shiftOut(dataPin, clockPin, data11);
shiftOut(dataPin, clockPin, data10);
shiftOut(dataPin, clockPin, data9);
shiftOut(dataPin, clockPin, data8);
shiftOut(dataPin, clockPin, data7);
shiftOut(dataPin, clockPin, data6);
shiftOut(dataPin, clockPin, data5);
shiftOut(dataPin, clockPin, data4);
shiftOut(dataPin, clockPin, data3);
shiftOut(dataPin, clockPin, data2);
shiftOut(dataPin, clockPin, data1);
//return the latch pin high to signal chip that it
//no longer needs to listen for information
digitalWrite(latchPin, 1);
if (amp >= 16 && amp < 32){
data1 = dataArray1[0];
data2 = dataArray2[amp];
//move 'em out
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
// This shifts 8 bits out MSB first,
//on the rising edge of the clock,
//clock idles low
//internal function setup
int i=0;
int pinState;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, OUTPUT);
//clear
digitalWrite(myDataPin, 0);
digitalWrite(myClockPin, 0);
//for each bit in the byte myDataOut
//NOTICE THAT WE ARE COUNTING DOWN in our for loop
//This means that %00000001 or "1" will go through such
//that it will be pin Q0 that lights.
for (i=15; i>=0; i--) { // THIS IS SOMETHING TO WATCH
//if the value passed to myDataOut and a bitmask result
// true then... so if we are at i=6 and our value is
// %11010100 it would the code compares it to %01000000
// and proceeds to set pinState to 1.
if ( myDataOut & (1<<i) ) {
pinState= 1;
else {
pinState= 0;
//Sets the pin to HIGH or LOW depending on pinState
digitalWrite(myDataPin, pinState);
digitalWrite(myClockPin, 1);
//stop
I don't have a handle on arrays yet, but again, this setup works for 8 LEDs per chip for one reason or another.
Thanks everyone. I can link to the datasheet if you think that would be useful.
