a simple Button to move a Servo [HELP]
Hi guys, here is my problem
I made a Keypad controlled servo in a secondary door to my office.
If I put the correct code it turns the servo that unlocks the door.
that works perfectly if I go from outside to inside but if I want to Exit I have no way to make the servo Turns.
So I decided to insert a simple Button ( that one used also for the ring bell) in order to unlock the door when I press it from inside.
Can someone Help me on implementing it?
here is the working code by now:
#include <Password.h>
#include <Keypad.h>
#include <Servo.h>
Servo myservo; //declares servo
Password password = Password( "1542" ); //password to unlock box, can be changed
const byte ROWS = 4; // Four rows
const byte COLS = 4; // columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 5, 4, 3, 2 };
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  Serial.write(254);
  Serial.write(0x01);
  delay(200);
  pinMode(11, OUTPUT);  //green light
  pinMode(12, OUTPUT);  //red light
  myservo.attach(13); //servo on digital pin 9 //servo
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  // initialize the pushbutton pin as an input:
void loop(){
  keypad.getKey();
  myservo.write(85);
  //take care of some special events
  void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
  case PRESSED:
  Serial.print("Enter: ");
  Serial.println(eKey);
  delay(10);
  Serial.write(254);
  switch (eKey){
    case 'A': checkPassword(); delay(1); break;
    case 'B': muoviUnPelo(); delay(1); break;
    case 'D': password.reset(); delay(1); break;
     default: password.append(eKey); delay(1);
void muoviUnPelo(){
  myservo.write(53);
  delay(50);
  myservo.write(49);
void checkPassword(){
if (password.evaluate()){  //if password is right open box
    Serial.println("Accepted");
    Serial.write(254);delay(1000);
    //Add code to run if it works
    myservo.write(51); //160deg
        digitalWrite(11, HIGH);//turn on
    delay(20000); //wait 5 seconds
    digitalWrite(11, LOW);// turn off
}else{
    Serial.println("Denied"); //if passwords wrong keep box locked
    Serial.write(254);
    delay(10);
    //add code to run if it did not work
    myservo.write(90);
    digitalWrite(12, HIGH); //turn on
    delay(500); //wait 5 seconds
    digitalWrite(12, LOW);//turn off
Thanks to everyone that will help
I guess the function muoviUnPelo() activates the lock.
Then you need something like
exitBtnVal = digitalRead(exitBtnPin);
if (exitBtnVal == LOW) {  // assumes LOW = pressed
   muoviUnPelo();
...R
