A simple game which make me crazy
Hello,
I am trying to code a simple game. I have a 20x4 lcd display and 3 buttons. The screen is working correctly and the buttons too (I've done some tests) so I think my problem is not hardware.
I'm trying to move a spaceship by pressing one button (up or down) But it doesn't work, at start the spaceship goes to line 1 row 2 (I don't know how this is possible because, my lcd.setCursor() are only in row 0) and if I press the up button, it goes to row 0 line 0. Nothing happens if I press the down button.
I tried several things but nothing worked.
// Asteroids
// goal is to avoid asteroids
// 1 button to move up, 1 button to move down, 1 button to start/stop the game
// include lcd library
#include <LiquidCrystal.h>
// lcd interface pin
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
// button interface
const int up = 12;
const int down = 13;
const int start = 11;
// graphics
byte spaceShip[8] = {
	B10000,
	B11000,
	B00100,
	B01111,
	B01111,
	B00100,
	B11000,
	B10000
// spaceship position
int spaceShipPosition = 0;
  // set up the LCD's number of columns and rows:
  lcd.begin(20,4);
  // set buttons as input
  pinMode(up, INPUT);
  pinMode(down, INPUT);
  pinMode(start, INPUT);
  digitalWrite(up, HIGH);
  digitalWrite(down, HIGH);
  digitalWrite(start, HIGH);
  // set graphics
  lcd.createChar(0, spaceShip);
  lcd.setCursor(0, spaceShipPosition);
  lcd.write(0);
  // move up
  if(digitalRead(up) == LOW) {
    MoveUp();
  // move down
  else if(digitalRead(down) == LOW) {
    MoveDown();
void MoveUp() {
  if(spaceShipPosition > 0) {
      lcd.clear();
      spaceShipPosition = spaceShipPosition - 1;
      lcd.setCursor(0,spaceShipPosition);
      lcd.write(0);
void MoveDown() {
  if(spaceShipPosition < 4) {
      lcd.clear();
      spaceShipPosition = spaceShipPosition + 1;
      lcd.write(0);
Do you think I can write a Move class to move the spaceship up and down and to move the asteroids ? (for exemple, I call Move(u) to move up, Move(a) to move the asteroids...)
For the asteroid moving, I think I'm going to use a list of lists which contains coords of asteroids. Is it a good idea ?
  1. Which Arduino are you using? On the Uno, there is a LED/resistor connected between pin 13 and ground, which means that you can't use the usual arrangement of a pushbutton connected between the pin and ground and the internal pullup enabled.
  2. I've read that the addressing of 20x4 LCDs is strange when the standard LCD library is used. I suggest you check out the Displays section of this forum.
Thanks for your answer. I use the Uno, so I connected my buttons on the 10, 11, 12 pins instead of 11, 12, 13.
Now, it's better, but when I press the down button, the spaceship goes in row 2 line 1 and when I press the up button, it goes in row 0 line 0.
I will check out the displays section :wink:
There are at least two more problems in your code (aside from the question about 20x4 adressing)
  1. MoveDown goes too far:
You probably want to write
if(spaceShipPosition < 3) {
  1. Wait until key is released or at least add some delay()
    In your "loop()" you will move up or down as long as your button is pressed: As long as you press the down button, you will call MoveDown(). At least do some delay():
  // move up
    MoveUp();
   delay(300);
  // move down
    MoveDown();
   delay(300);
Oliver
Thank you for your reply, I've just found it myself (and it works :))
Here is my code :
// Asteroids
// button interface
const int up = 11;
const int down = 12;
const int start = 10;
// graphics
	B10000,
	B11000,
	B00100,
	B01111,
	B01111,
	B00100,
	B11000,
	B10000
  lcd.begin(20,4);
  pinMode(up, INPUT);
  // set graphics
  lcd.write(0);
  // move up
    MoveUp();
  // move down
    MoveDown();
void MoveUp() {
      lcd.clear();
      lcd.write(0);
void MoveDown() {
      lcd.clear();
      lcd.write(0);
