I am new to arduino uno so please excuse the ignorance.
I am turning a stirrer shaft using a DC motor. I have managed to control the speed of the motor and the direction but I now want to read the speed (RPM) on an LCD. My thoughts are to use a Rotary encoder? Does anyone have another solution to this?
Thanks
put a magnet on the shaft and use a hall sensor to count pulses ?
Drill a hole through the shaft and shine a led on a LDR through the hole? - with two hole you can detect 90 degrees angles ![]()
put mirror on the shaft and detect the reflection ....
more?
Great I am on it with the hall effect sensor and magnet.
Thank you.
