A single WS2812B RGB LED on a Mega 2560 - help am I missing anything?
Hi all, any help appreciated getting just one of these to work.
Been playing with the Mega for a few weeks got other stuff to work easy enough (real time clock oled display etc) and when my new RGB led arrived in the post I expected the same, but no – can’t even get one to light up.
I have the fast led and also the neo pixel library but no joy. No compile errors either and no errors when uploading to the mega.
Can anyone suggest anything that I should be checking or looking at etc? Tried two of them – should I try more could be a dud batch? I have also checked other posts and sample code.
New to electronics but not new to coding.
Simple LED hook-up. Data pin 6 (tried others). Ground to ground, positive to positive running the following test code.
#include "FastLED.h"
// How many leds in your strip?
#define NUM_LEDS 1
// For led chips like Neopixels, which have a data line, ground, and power, you just
// need to define DATA_PIN.  For led chipsets that are SPI based (four wires - data, clock,
// ground, and power), like the LPD8806 define both DATA_PIN and CLOCK_PIN
#define DATA_PIN 6
#define CLOCK_PIN 13
// Define the array of leds
CRGB leds[NUM_LEDS];
      // Uncomment/edit one of the following lines for your leds arrangement.
      // FastLED.addLeds<TM1803, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<TM1804, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<TM1809, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
  	  FastLED.addLeds<NEOPIXEL, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<UCS1903, DATA_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2801, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<SM16716, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<LPD8806, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<SM16716, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
      // FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
  // Turn the LED on, then pause
  leds[0] = CRGB::Red;
  FastLED.show();
  // Now turn the LED off, then pause
  leds[0] = CRGB::Black;
  FastLED.show();
Are you sure, that you have specified the right chipset?
Try at first the fastled examples with nothing else connected.
do you have the GROUND of the power supply and the led strip also connected to the GROUND of the arduino board?
I need to ask, how are you handling = #define CLOCK_PIN 13
try the following “ColorPalette” from the Fastled
#include <FastLED.h>
#define LED_PIN     6
#define NUM_LEDS    1
#define BRIGHTNESS  64
#define LED_TYPE    WS2811
#define COLOR_ORDER GRB
#define UPDATES_PER_SECOND 100
CRGBPalette16 currentPalette;
TBlendType    currentBlending;
extern CRGBPalette16 myRedWhiteBluePalette;
extern const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM;
  delay( 3000 ); // power-up safety delay
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness(  BRIGHTNESS );
  currentPalette = RainbowColors_p;
  currentBlending = BLEND;
  ChangePalettePeriodically();
  static uint8_t startIndex = 0;
  startIndex = startIndex + 1; /* motion speed */
  FillLEDsFromPaletteColors( startIndex);
  FastLED.show();
  FastLED.delay(1000 / UPDATES_PER_SECOND);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
  uint8_t brightness = 255;
  for( int i = 0; i < NUM_LEDS; i++) {
    leds[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
    colorIndex += 3;
void ChangePalettePeriodically()
  uint8_t secondHand = (millis() / 1000) % 60;
  static uint8_t lastSecond = 99;
  if( lastSecond != secondHand) {
    lastSecond = secondHand;
    if( secondHand ==  0)  { currentPalette = RainbowColors_p;         currentBlending = BLEND; }
    if( secondHand == 10)  { currentPalette = RainbowStripeColors_p;   currentBlending = NOBLEND;  }
    if( secondHand == 15)  { currentPalette = RainbowStripeColors_p;   currentBlending = BLEND; }
    if( secondHand == 20)  { SetupPurpleAndGreenPalette();             currentBlending = BLEND; }
    if( secondHand == 25)  { SetupTotallyRandomPalette();              currentBlending = BLEND; }
    if( secondHand == 30)  { SetupBlackAndWhiteStripedPalette();       currentBlending = NOBLEND; }
    if( secondHand == 35)  { SetupBlackAndWhiteStripedPalette();       currentBlending = BLEND; }
    if( secondHand == 40)  { currentPalette = CloudColors_p;           currentBlending = BLEND; }
    if( secondHand == 45)  { currentPalette = PartyColors_p;           currentBlending = BLEND; }
    if( secondHand == 50)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = NOBLEND;  }
    if( secondHand == 55)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = BLEND; }
// This function fills the palette with totally random colors.
void SetupTotallyRandomPalette()
  for( int i = 0; i < 16; i++) {
    currentPalette[i] = CHSV( random8(), 255, random8());
void SetupBlackAndWhiteStripedPalette()
  // 'black out' all 16 palette entries...
  fill_solid( currentPalette, 16, CRGB::Black);
  // and set every fourth one to white.
  currentPalette[0] = CRGB::White;
  currentPalette[4] = CRGB::White;
  currentPalette[8] = CRGB::White;
  currentPalette[12] = CRGB::White;
// This function sets up a palette of purple and green stripes.
void SetupPurpleAndGreenPalette()
  CRGB purple = CHSV( HUE_PURPLE, 255, 255);
  CRGB green  = CHSV( HUE_GREEN, 255, 255);
  CRGB black  = CRGB::Black;
  currentPalette = CRGBPalette16(
    green,  green,  black,  black,
    purple, purple, black,  black,
    purple, purple, black,  black );
const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM =
  CRGB::Red,
  CRGB::Gray, // 'white' is too bright compared to red and blue
  CRGB::Blue,
  CRGB::Black,
  CRGB::Red,
  CRGB::Gray,
  CRGB::Blue,
  CRGB::Black,
  CRGB::Red,
  CRGB::Red,
  CRGB::Gray,
  CRGB::Gray,
  CRGB::Blue,
  CRGB::Blue,
  CRGB::Black,
  CRGB::Black
If you have a led controller without a clock line you add the controller with
FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS);
With clocked led drivers you specifiy the clock pin after the data pin:
FastLED.addLeds<LED_TYPE, DATA_PIN, CLOCK_PIN, COLOR_ORDER>(leds, NUM_LEDS);
if you are using a led strip without "clock", what "#define CLOCK_PIN 13" says is irrelevant.
FYI the ws2812b leds do not have a separate clock line.
Check this: the data line on the strip is one-way, so do you have the correct end of the strip connected to the Arduino? There are usually some arrows printed somewhere along the strip indicating the direction of data.
Paul
Oops... only one led, not a strip. So have you got the data-in connected to the Arduino, rather than the data-out?
