I have problem in uploading the below sketch.the Arduino ide always give error'CNC_controller.ino: In function 'void setup()':
uCNC_controller:94: error: 'initMotors' was not declared in this scope
uCNC_controller.ino: In function 'void loop()':
uCNC_controller:123: error: 'process_command' was not declared in this scope
uCNC_controller:130: error: 'powerdown' was not declared in this scope"
I have been told to replace the stepper library with a newer one.i have tried several versions of Arduno.ranging from old IDE to recently release ones.the error is the same.and I found the stepper library is built-in of each arduino IDE.I can't find a advanced stepper library.now i guess the problem is the coding.maybe it contains bugs.but i am not sure.so i post here hoping someone guide me walk over it.
#include <Servo.h>
#include <Stepper.h>
/* Version of this progam */
float uCNC_Version = 1.0;
/* Development functions - broken code*/
//#define BUILTIN 1
//#define BROKEN 1
/* Conversion factor of steps per millimeter */
float stepsPerMillimeter_X = 200 / 17.1;
float stepsPerMillimeter_Y = -200 / 17.1;
float stepsPerMillimeter_Z = 200 / 17.1;
/* Unit conversion factor */
float conversionFactor = 1; // 1 for mm 25.4 for inches
/* Stepper library initialization */
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
Stepper myStepper1(stepsPerRevolution, 8,9,10,11);
Stepper myStepper2(stepsPerRevolution, 4,5,6,7);
Stepper myStepper3(stepsPerRevolution, 17,16,19,18);
/* Servo functions and limits */
Servo myServo;
int servoPosMax=83;
int servoPosMin=70;
int servoToolInc=10;
float servoPosZfactor=1.0;
/* Mode selector for the motors (see documentation) */
int motorMode = 0;
/* X,Y,Z in absolute steps position */
int X = 0;
int Y = 0;
int Z = 0;
/* X,Y,Z in measurement value*/
float posX = 0.0;
float posY = 0.0;
float posZ = 0.0;
/* Tools and Feeds and Coolants */
int tool = 0;
int spindle = 0;
int coolant1 = 0;
int coolant2 = 0;
/* Spindle speed (M3 parameter)*/
int spindleSpeed = 0;
int led = 13;
#define COMMAND_SIZE 128
uint8_t command_line[COMMAND_SIZE];
uint8_t sin_count=0;
uint16_t no_data = 0;
uint8_t asleep = 0;
// LED (Laser output)
pinMode(led, OUTPUT);
// General pupose (coolant 1) output
pinMode(2, OUTPUT);
// General pupose (coolant 2) output
pinMode(3, OUTPUT);
/* Init the steppers and servo */
initMotors();
void clear_command_string() {
for (int i=0; i<COMMAND_SIZE; i++)
command_line[i] = 0;
sin_count = 0;
uint8_t c;
Serial.println("ready");
while (true) {
//read in characters if we got them.
if (Serial.available() > 0) {
c = (uint8_t)Serial.read();
no_data = 0;
asleep = 0;
command_line[sin_count++] = c;
else {
no_data++;
delayMicroseconds(150);
if (sin_count && (c == '\n' || no_data > 100)) {
command_line[sin_count] = 0;
process_command(command_line);
//sin_count=0;
clear_command_string();
if (no_data == 60000) {
if (!asleep) {
powerdown();
asleep=1;
