A strange output for a simple code
Dear All,
When I am trying to convert a string ( "1000.01" ) to a floating pointumber and multiply the value by 100. I get the output as below. I am using Arduino Mega2560 board with Arduino IDE version 1.8.19. My code is given at the end of this post.
Output:
dummy_float:1000.01
dummy:100000
If I repeat this with another string in the atof function the output was as shown below. The code is attached for your kind reference. Please help.
Case1:
String : "1000.02"
dummy_float:1000.02
dummy:100001
Case2:
String : "1000.03"
dummy_float:1000.03
dummy:100003
Code:
#include <stdio.h>
#include <stdlib.h>
unsigned long dummy;
float dummy_float;
   dummy_float=atof("1000.01");
   dummy=(float)dummy_float*100.0;
   Serial.print("\n");
   Serial.print(dummy_float);
   Serial.print("\n");
   Serial.print(dummy);
Can you say what it is that is "strange"?
Perhaps you want:
dummy = uint32_t (dummy_float*100.0);
Or does that yield the same result?
Floating point numbers may not be exactly what you see.
Try this code and see the result:
#include <stdio.h>
#include <stdlib.h>
float dummy_float;
   dummy=(float)dummy_float*10000.0;
   Serial.print("\n");
   Serial.print(dummy_float,6);
   Serial.print("\n");
10000099
type or paste code here
Thank you all for your fast reply.
ruilviana's solution worked.
Since I need only two decimal places I have modified the line as follows.
dummy=(dummy_float+0.001)*100.0;
Modified code:
#include <stdio.h>
#include <stdlib.h>
float dummy_float;
   Serial.print("\n");
   Serial.print("\n");
