A stupid mistake
Last month, I had single sided boards made for a display project, and after sending the Gerber files to the pcb manufacturer, I went and chatted with them about the drill size for the 26,000 LEDs. ( the drillfile had the default 0.6mm )
I needed the LEDs to "sit" on the stops of the legs, which nowadays are so small you can hardly see the stop ( the flattened part of each leg )
I got a sample from the LED manufacturer, and we decided that they would drill the holes 0.7mm, which worked out fine, the boards were populated with no problem.
I changed the hole size on my library.
This month I had to make another order with 15,500 LEDs, but between myself and the guy at the pcb manufacturers, we forgot to change the drillplan to 0.7mm, and they made all the boards with 0.6mm holes !
We only had 2 days to redrill all 31,000 holes ! They did half the boards, one at a time back on the cnc drill, and I did the rest working all last weekend using my little Dremel drill press. but at least I could do 5 boards at a time. Thank heavens it was single sided and not thru hole !
The next order looks like 65,000 LEDs I won't make this mistake again ! ...
Holy rework Batman.
Rob
At least the holes were too small. Would have been a lot worse if they'd been too big.
dxw00d:
"I've cut this board three times and it's still too short!"
Curiosity gets the better of me. What in the world are so many LEDs for? Making one of those electronic billboards the hard way?
I wanne know to, why do you need so many leds?
And congratulations for your effort.
Best regards
Jantje
"I've cut this board three times and it's still too short!" love it, confirms the old adage " measure twice, cut once "
In this case I forgot to check the drill plan file ( and the factory forgot the previous decision on hole size )
I make electronic scoreboards and signs www.scorebauds.co.za and have landed a nice job for some export displays.
For my smaller one-off runs of scoreboards, I havn't bothered with SMD LEDs, but I think I will have to head that way with these bigger jobs coming in - but of course its now a case of not havng the time to source the LEDs ( I have luckily found a supplier of reliable of 5mm LEDs from China, so I might get some samples of smd types with the next order )
The assembly of the pcbs is locally done ( South Africa ) so I dont feel guilty buying the LEDs from China, they all come from there anyway, even if I buy locally at 8 times the price !
Boffin1:
Nice web site, sounds like an interesting business! Are there AVRs in them thar scoreboards?
The website is in urgent need of updating, but I dont have the time, working 24/7 rcovering from being wiped out last year.
There is all sorts of technology in the boards you see there, from cmos. Holtek encoder/decoders, and Atmegas, sort of reflects my learning curve !
Scorebauds
I love that play on words :slight_smile:
You seem to have built up a nice business there.
Rob
"Scorebauds
I love that play on words "
I get some funny variations and looks from people who have never heard of baud rate though
Need a better model for that Red/Green substitution board...
Cool Idea, glad to hear that its keeping you out of trouble. Lot of businesses aren't doing that right now...
I must take that substitution board off the website, its way too overcomplicated.
I have a much simpler version in the pipeline, but never seem to get the time to prototype it !
Youre right, business has been really tough for the last couple of years, but I get the sales of the scoreboards from referals - its viral, every new board gets seen by the visiting teams etc. and orders trickle in.......
Sounds like you have a good offer for a fair price on a living market.
Again congratulations, well done.
Best regards
Jantje
haha, nice work guys
Wow sounds good! Hope you get on well with that!
I finally got his batch of displays out , after weeks of 18 hour days .
Note to self, and anyone considering farming out pcb assembly ( I know its fairly obvious ) :-
  1. Get samples of components - the latest batch of ultrabright LEDs that I have coming from China next week, have the Anode with the short leg, and the flat on the rim ! When I queried the sample , the supplier said " thats right, we call it reversed polarity " ????
  2. Chat to the pcb manufacturing guy, take samples of each component, agree hole size, solder mask clearances , and silk screen.
  3. Take sample board to assembling guys, run through their routine.
    I supplied a perspex jig this time to drop over the LEDs when the boards go over the solder bath to keep the aligned, and they say its much easier to put on than the aluminium one I gave them before, they can see which LED is crooked.
    Thier feedback is priceless.
  4. Don't just give up and get it made in China ( even if most components are )
I put " Proudly made in South Africa " on my products ( even if I sit all weekend drilling out holes :slight_smile:
