According to the datasheet of Atmega32U4 the internal pull-up resistors have a value between 20kΩ and 50kΩ, so theoreticaly it should be safe, but I need your advice before trying to connect it like that.
Please supply full code and a circuit diagram of your project showing your switches and output.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Don't judge my lazy "debounce" it's just a quick 1minute sketch. So it's safe you are saying? Thanks, I will try that and pray it won't go down in flames
oomek:
What you are doing is a little unconventional...
You could just as easily bridge the switch across your input pin and the 3V3 pin, no?
The reason for doing it like that is that I have already premade 2 pin arcade button harnesses. I'm planning to use my A-Star boar as a supplementary board to my IPAC2 controller. I just need 4 extra buttons, so I'm not sad about the reason I'm wasting some i/o pins.
