Hi.
I have an Arduino Mega 2560 running a Program as simple as could be:
#include <MIDI.h>
#define LED_GRUEN 45
#define LED_ROT 52
#define LED_BLAU1 47
#define LED_BLAU2 50
#define TASTER_UL 49
#define TASTER_UM 51
#define TASTER_UR 53
#define POTI_PORT 15
#define TIMELINE 3
void setup(){
MIDI.begin();
void loop(){
delay(200);
It should do nothing but init my Serial Output with 31250 Baud.
BUT, when uploading my Code and starting it on Arduino,on the Midi Output these Data are sent (had to cut more than half of the Log, because i exceeded the maximum of 9500 Characters in this Post!):
21:12:17.590 From Port 1 Program 1 33
21:12:17.591 From Port 1 Program 1 0
21:12:17.591 From Port 1 Program 1 113
21:12:17.591 From Port 1 Program 1 28
21:12:17.592 From Port 1 Reset
21:12:17.595 From Port 1 Program 1 32
21:12:17.595 From Port 1 Program 1 0
21:12:17.598 From Port 1 Program 1 97
21:12:17.599 From Port 1 Program 1 2
21:12:17.599 From Port 1 Program 1 35
21:12:17.599 From Port 1 Reset
21:12:17.602 From Port 1 Program 1 96
21:12:17.603 From Port 1 Program 1 2
21:12:17.603 From Port 1 Program 1 3
21:12:17.603 From Port 1 Reset
21:12:17.607 From Port 1 Program 1 97
21:12:17.607 From Port 1 Program 1 2
21:12:17.607 From Port 1 Program 1 3
21:12:17.607 From Port 1 Reset
21:12:17.611 From Port 1 Program 1 96
21:12:17.611 From Port 1 Program 1 2
21:12:17.612 From Port 1 Active Sense
21:12:17.615 From Port 1 Program 1 97
21:12:17.615 From Port 1 Program 1 2
21:12:17.615 From Port 1 Stop
21:12:17.619 From Port 1 Program 1 96
21:12:17.619 From Port 1 Program 1 2
21:12:17.620 From Port 1 Invalid 1 bytes
21:12:17.623 From Port 1 Program 1 97
21:12:17.623 From Port 1 Program 1 2
21:12:17.624 From Port 1 Program 1 2
21:12:17.624 From Port 1 Invalid 1 bytes
21:12:17.628 From Port 1 Program 1 32
21:12:17.629 From Port 1 Program 1 64
21:12:17.662 From Port 1 Program 1 33
21:12:17.662 From Port 1 Program 1 64
21:12:17.699 From Port 1 Program 1 32
21:12:17.699 From Port 1 Program 1 0
21:12:17.736 From Port 1 Program 1 33
21:12:17.736 From Port 1 Program 1 0
21:12:17.773 From Port 1 Program 1 32
21:12:17.773 From Port 1 Program 1 64
21:12:17.810 From Port 1 Program 1 33
21:12:17.810 From Port 1 Program 1 64
21:12:17.846 From Port 1 Program 1 34
21:12:17.847 From Port 1 Program 1 0
21:12:17.883 From Port 1 Program 1 35
21:12:17.883 From Port 1 Program 1 0
21:12:17.920 From Port 1 Program 1 34
21:12:17.920 From Port 1 Program 1 64
21:12:17.957 From Port 1 Program 1 35
21:12:17.957 From Port 1 Program 1 64
21:12:17.994 From Port 1 Program 1 34
21:12:17.994 From Port 1 Program 1 0
21:12:18.030 From Port 1 Program 1 35
21:12:18.031 From Port 1 Program 1 0
21:12:18.068 From Port 1 Program 1 34
21:12:18.068 From Port 1 Program 1 64
21:12:18.104 From Port 1 Program 1 35
21:12:18.105 From Port 1 Program 1 64
21:12:18.141 From Port 1 Program 1 34
21:12:18.141 From Port 1 Program 1 0
21:12:18.147 From Port 1 Program 1 35
21:12:18.147 From Port 1 Program 1 2
21:12:18.167 From Port 1 Program 1 34
21:12:18.167 From Port 1 Program 1 64
21:12:18.174 From Port 1 Program 1 35
21:12:18.175 From Port 1 Program 1 66
21:12:18.180 From Port 1 Program 1 34
21:12:18.181 From Port 1 Note Off 1 D-2 36
21:12:18.182 From Port 1 Note Off 1 C1 36
21:12:18.183 From Port 1 Note Off 1 C1 36
21:12:18.183 From Port 1 Note Off 1 A-2 3
21:12:18.184 From Port 1 Note Off 1 A-1 41
21:12:18.185 From Port 1 Note Off 5 C#0 34
21:12:18.186 From Port 1 Note Off 5 D-2 2
21:12:18.186 From Port 1 Note Off 5 D6 98
21:12:18.187 From Port 1 Note Off 5 F#3 66
21:12:18.188 From Port 1 Note Off 5 D6 98
21:12:18.189 From Port 1 Note Off 5 F#3 66
21:12:18.190 From Port 1 Aftertouch 3 F#3 98
21:12:18.191 From Port 1 Aftertouch 3 D6 66
21:12:18.192 From Port 1 Aftertouch 3 F#3 98
21:12:18.192 From Port 1 Aftertouch 3 D6 66
21:12:18.193 From Port 1 Aftertouch 3 F#3 34
21:12:18.194 From Port 1 Pitch Wheel 3 322
21:12:18.195 From Port 1 Pitch Wheel 3 4450
21:12:18.196 From Port 1 Pitch Wheel 3 322
21:12:18.196 From Port 1 Pitch Wheel 3 4450
21:12:18.197 From Port 1 Pitch Wheel 3 322
21:12:18.198 From Port 1 Pitch Wheel 3 -3806
21:12:18.198 From Port 1 Pitch Wheel 3 -3838
21:12:18.199 From Port 1 Pitch Wheel 3 290
21:12:18.200 From Port 1 Note Off 3 A#0 66
21:12:18.203 From Port 1 Note Off 3 D-1 10
21:12:18.203 From Port 1 Active Sense
21:12:18.209 From Port 1 Program 3 47
21:12:18.209 From Port 1 Program 3 38
21:12:18.212 From Port 1 Aftertouch 15 B2 104
21:12:18.212 From Port 1 Note Off 15 F#0 57
21:12:18.213 From Port 1 Note Off 15 A#3 29
21:12:18.214 From Port 1 Pitch Wheel 4 839
21:12:18.215 From Port 1 Pitch Wheel 4 -2677
21:12:18.216 From Port 1 Pitch Wheel 4 1162
21:12:18.218 From Port 1 Note Off 4 D1 104
21:12:18.218 From Port 1 Note Off 4 G#6 104
21:12:18.219 From Port 1 Note Off 4 G#6 104
21:12:18.220 From Port 1 Note Off 4 G#6 104
21:12:18.221 From Port 1 Note Off 4 G#6 104
21:12:18.222 From Port 1 Note Off 4 G#6 104
21:12:18.223 From Port 1 Note Off 4 G#6 104
21:12:18.223 From Port 1 Note Off 8 E2 31
21:12:18.225 From Port 1 Note Off 16 E5 70
21:12:18.226 From Port 1 Program 11 13
21:12:18.227 From Port 1 Note Off 3 F4 82
21:12:18.228 From Port 1 Note Off 3 F#-2 46
21:12:18.228 From Port 1 Note Off 3 D5 3
21:12:18.229 From Port 1 Note Off 3 C-1 3
21:12:18.230 From Port 1 Note Off 3 G-2 101
21:12:18.230 From Port 1 Note Off 3 C#2 88
21:12:18.231 From Port 1 Active Sense
21:12:18.237 From Port 1 Note Off 8 G-2 34
21:12:18.239 From Port 1 Note Off 11 C#1 88
21:12:18.240 From Port 1 Aftertouch 4 A#1 72
21:12:18.241 From Port 1 Note Off 14 D#3 9
21:12:18.246 From Port 1 Pitch Wheel 7 -7610
21:12:18.247 From Port 1 Note Off 11 A#-2 32
21:12:18.248 From Port 1 Note Off 3 A0 64
21:12:18.252 From Port 1 Note Off 13 A#-2 102
21:12:18.253 From Port 1 Note Off 4 A0 64
21:12:18.254 From Port 1 Program 1 38
21:12:18.255 From Port 1 Program 1 20
21:12:18.255 From Port 1 Program 1 37
21:12:18.256 From Port 1 Program 1 59
Turning Midi Through off won´t change a thing.
What is this and how can i get rid of this useless Traffic on my Midiport?
