A UNO + LCD 2x16 Keypad Shield: no more pins for relays
Hello there! :slight_smile:
I'm new on this, after play few hours with the Arduino UNO board and the LCD Keypad Shiel I took note about there's no more pins available for 4 Relay Module board connection.
So, what can I do?
Also in the future I would like to connect an pyrometer (analog).
TY!
I don't think the passage of time affects the number of available pins.
Jump up to Atmega1284P. 32IO, 16KSRAM, DIP available. Here's a board I offer in Uno type form factor, others available also:
http://www.crossroadsfencing.com/BobuinoRev17
dezagus:
So, what can I do?
Is it a mechanical problem (how to connect cables to yet unused pins), or are too many pins already in use?
DrDiettrich:
I have free:
  • AREF
  • ICSP
The LCD Keypad Shield have an clone of few or their pins, more specify:
  • Digital 1 (TX) to 7 pin
  • Analog IN: A1 to A4 pin
  • POWER: V1N to 3.3v pin
Including ICSP and the analog pins you have a total of 11 output pins available. That's enough for a 4 relay module board, isn't it?
Why not using an I2C LCD display?
Thank you everybody. Finally I solve my problem!!! :slight_smile:
