Hi folks, i'm a Little new in the Arduino thopic, Actualy i'm programing a very Basic control system for humidity in a fungículture project, i think that i almost have the programing done, but i'm stuck in a bug that modifies a very important variable, this bug writes a variable whit a value close to 70 in a spot in the code that doesn't even reads the value, it wolud be great if you can helpme, here is the function and the spot where the variable gets modified:
void Leer_sensor(){
//lee temperatura y humedad en el sensor 1
T[1]=sensor1.readTemperature();
Hl[1]=sensor1.readHumidity();
// lee termperatura y humedad en el sensor 2
T[2]=sensor2.readTemperature();
Hl[2]=sensor2.readHumidity();
//promedia temperatura y humedad de los sensores
Hl[3]=(Hl[1]+Hl[2])/2; // here is the line where the variable "Modo" gets modified
Serial.println(Modo);
T[3]=(T[1]+T[2])/2;
Serial.println("Sensado Realizado");
In this function the arduino reads the humidity and temperature of two DHT 22 sensors and promediates it, the variables are declared as:
// the variables used in the function
byte T[3];
byte Hl[3];
// the variable that gets bugged
byte Modo=0;
I proceed to add the whole code:
#include <TimerOne.h>
#include <Wire.h>
#include <DHT.h>
#include <DHT_U.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
// Variables del sensor
byte sens1=5;
byte sens2=6;
// variables de manejo temperatura y humedad
byte T[3];
byte Hl[3];
// variables de ejecucion de los botones
boolean button[3]={7,8,9};
int state_count[3]={0,0,0};
volatile boolean state=0;
volatile boolean btn[3]={0,0,0};
// variables de ejecucion del tiempo
volatile long seg = 0;
long reseteo=3;
//variables de control
byte Modo=0;
byte Umbral_humedad[2]={70,95};
byte Modificacion=0;
byte Temporizador[3]={8,0,0};
long Tiempo_ventilacion=(Temporizador[0]*3600+Temporizador[1]*60+Temporizador[2]);
// variables de estado
volatile boolean Proceso_ventilacion=0;
volatile boolean Proceso_Humifdificar=0;
//declaracion de lo sensores
DHT sensor1(sens1,DHT22);
DHT sensor2(sens2,DHT22);
//inicializacion de comunicacion con lo sensores
Wire.begin();
sensor1.begin();
sensor2.begin();
// inicializacion de comunicacion con el display
display.begin(SSD1306_SWITCHCAPVCC,0x3C);
// inicializa la interrupcion por boton
attachInterrupt(digitalPinToInterrupt(3),leer_boton,LOW);
//inicia la comunicacion serial con el
// inicializa las interrupciones programada por tiempo
Timer1.initialize(1000000);
Timer1.attachInterrupt(segundero);
//declara los pines de entrada
for (int i=0;i<3;i++){
pinMode(button[i],INPUT);
//ejecuta la primera lectura y mostrado de la informacion en el display
Modo=0;
Leer_sensor();
Ordenar_display();
// Si el sistema se encuentra en modo de ejecucion esta accion se ejecuta cada 3 segundos
if (seg==reseteo && Modo==0){
//se acomoda tiepo de ejecucion
reseteo=seg+3;
Serial.println("Orden Sensado");
//se ejecutan las funciones de lectura del sensor y se muestran los datos en la pantalla
Leer_sensor();
Ordenar_display();
Serial.println("Refrescado");
//En caso de tener una humedad inferior al minimo de humbral se inicia el proceso de humidificacion
if (Hl[3]<=Umbral_humedad[0]){
Proceso_Humifdificar=1;
//en caso de alcanzar la humedad maxima del humbral se detiene el proceso de humidificacion
else if(Hl[3]>=Umbral_humedad[1]){
//al presionar un boton se ejecuta el proceso
if (state==1){
// realiza la comprobacion de los elementos
interfaz_estados();
Serial.print("state reset: ");
//resetea el estado
state=0;
Serial.println(state);
//se resetea la lectura de los botones
btn[i]=0;
// funcion que se ejecuta con la intrrupcion programada
void segundero(){
seg=seg+1;
Serial.println(seg);
// funcion que se ejecuta al presionar un boton
void leer_boton(){
Serial.print(" state input: ");
//Si el estado de le ctura es 0 procedera a identificar los botones presionados y a desencadenar sus efectos
if (state==0){
Serial.println("entrada: ");
//realiza la lectura de los botones presionados
btn[i]=digitalRead(button[i]);
Serial.print(i);
Serial.print("\t");
Serial.println(btn[i]);
//marca el estado de lectura como realizado
state=1;
Serial.print("state Output: ");
Serial.print(state);
//funcion que se ejecuta cuando se desea leer el sensor
void Leer_sensor(){
Hl[3]=floor((Hl[1]+Hl[2])/2);
T[3]=floor((T[1]+T[2])/2);
//Funcion que realiza la configuracion y visualizacion del display
void Ordenar_display(){
//se limpia la memoria del display
display.clearDisplay();
//se configuran los comandos base del display
display.setTextColor(WHITE);
display.setTextSize(1);
//Ubicacion de la primera linea del display
display.setCursor(0,0);
//visualizacion de la informacion sobre la humedad
display.print("Hm:");
display.print(Hl[3]);
display.print("%");
//Ubicacion del titulo de humbral y visualizacion de este
display.setCursor(40,0);
display.print("Umbral Humedad");
//ubicacion de la segunda linea de informacion en el display
display.setCursor(0,10);
display.print("T:");
display.print(T[3]);
display.print("C");
// si el dispositvo se encuentra en modificacion de humbral de humedad 1 muestra un indicador
if (Modo==1){
display.setCursor(35,10);
display.print(">");
//ubicacion y visualizacion del primer valor de humbral de humedad
display.setCursor(40,10);
display.print("H1:");
display.print(Umbral_humedad[0]);
display.print("%");
// si el dispositvo se encuentra en modificacion de humbral de humedad 2 muestra un
if (Modo==2){
display.setCursor(78,10);
display.print(">");
//ubicacion y visualizacion del segundo valor de humbral de humedad
display.setCursor(83,10);
display.print("H2:");
display.print(Umbral_humedad[1]);
display.print("%");
//ubicacion de la tercera linea de informacion
display.setCursor(0,20);
// visualizacion de los periodos de ejecucion del temporizador de ventilacion
display.print("Timer:");
display.setCursor(40,20);
// si el Dispositivo se encuentra en
if (Modificacion==0 && Modo==1){
display.print(">");
if(Temporizador[0]<10){
display.print("0");
display.print(Temporizador[0]);
display.print(":");
if (Modificacion==0&&Modo==1){
display.print(">");
if(Temporizador[1]<10){
display.print("0");
display.print(Temporizador[1]);
display.print(":");
display.print(">");
if(Temporizador[2]<10){
display.print("0");
display.print(Temporizador[2]);
if (Modo==1){
display.print("<");
Serial.println("Configuracion display");
display.display();
void interfaz_estados(){
if (btn[1]==1){
Modo++;
if (Modo==4){
Modo=0;
switch (Modo){
case 0:
state=0;
case 1:
if (btn[1]==1){
Umbral_humedad[0]++;
if (Umbral_humedad[0]==Umbral_humedad[1]){
Umbral_humedad[0]=Umbral_humedad[1]-1;
if (btn[2]==1){
Umbral_humedad[0]--;
if (Umbral_humedad[0]==10){
Umbral_humedad[1]=11;
case 2:
if (btn[1]==1){
Umbral_humedad[1]++;
if (Umbral_humedad[1]==100){
Umbral_humedad[1]=99;
if (btn[2]==1){
Umbral_humedad[1]--;
if (Umbral_humedad[1]==Umbral_humedad[0]){
Umbral_humedad[1]=Umbral_humedad[0]+1;
case 3:
if (btn[1]==1){
Modificacion++;
if (Modificacion=3){
Modificacion=0;
if (btn[2]==1){
switch(Modificacion){
case 0:
Temporizador[0]++;
if (Temporizador[0]=24){
Temporizador[0]=0;
case 1:
Temporizador[1]++;
if (Temporizador[1]=60){
Temporizador[1]=0;
case 2:
Temporizador[2]++;
if (Temporizador [0]==0 && Temporizador[1]==0){
Temporizador[2]=3;
else if(Temporizador[2]=60){
Temporizador[2]=0;
