A very Long and a Short delay on the same code
Hello everyone, I'm new in this Arduino stuff, I downloaded a code for PLX DAQ, and It worked, the person in charge told me he wanted a delay of 5 minutes between each read (analogRead) which was easy, but then he also told me to add a digitalWrite If the analog sensor raises over 800.
As you can see It can't be done with a single delay because the digital write will take 5 minutes to perform It's action. I have been readeing about Millis but I don't know how to implment it on my code.
Here Is my code:
float pinoPotenciometro = 0;
int linea = 0;
int LABEL = 1;
int valor = 0;
void setup(){
Serial.println("CLEARDATA");
Serial.println("LABEL,Hora,valor,linea");
void loop(){
valor = analogRead(pinoPotenciometro);
linea++;
Serial.print("DATA,TIME,");
Serial.print(valor);
Serial.print(",");
Serial.println(linea);
if (linea > 100)
linea = 0;
Serial.println("ROW,SET,2");
delay(300000);
if(analogRead(A0)>=800){
  digitalWrite(7,HIGH);
  delay(1000);}
  if(analogRead(A0)<=800){
  digitalWrite(7,LOW);
  delay(1000);}
moderator added code tags
if you do CTRL-T in the IDE you get more readable code!
some refactoring to remove the delay calls and replace with millis()...
try this variation
const int pinoPotenciometro = A0;
const unsigned long interval = 5 * 60 * 1000UL; // UL stands for unsigned long
unsigned long lastWrite = 0;
unsigned long lastEvent = 0;
int linea = 0;
int LABEL = 1;
int valor = 0;
  // MAKE MEASUREMENT
  // SEND TO PLXDAQ EVERY 5 MINUTES
  if (millis() - lastWrite >= interval)
    lastWrite += interval;  // set truigger for next time
    linea++;
    Serial.print(",");
    // UPDATE ADMISITRATION
    if (linea > 100)
      linea = 0;
  // TAKE ACTION IF NEEDED
  if (valor >= 800)
    digitalWrite(7, HIGH);
    lastEvent = millis();
  if (millis() - lastEvent >= 1000)
    digitalWrite(7, LOW);
robtillaart Thank you so much, It worked, since i'm a total noob I'm gonna ask this. I heard If you use millis() in about 50 days the code will stop working. Is It true?
kazplat:
Absolutely false. But it will likely happen if you didn't use unsigned long variables as time stamps.
@kazplat
Please look at this:
