A "virgin ATMEGA328P" can be write without clock crystal please ?
Hi there all,
I just play with MiniCore bootloader and I program some 328P that I have around,
using internal 4mHz clock by using an USBASP programmer.
The problem is that some of my 328P is write and some of 328P is not write.
But if I program the "328P not writed" with an external 16mHz crystal at first time,
then I can reprogram it at second time without using an external crystal.
So, because I don't need an external crystal on my final project,
and because I'll order some PCB with already soldered ATMEGA328P (SMD format),
I want to know if I must put an external crystal or not on this PCB in order to write
the bootloader at first time.
Thanks all in advance
Denis
No crystal is needed on a fresh from factory ATMEGA328 chip. It is set at 8MHz internal with a divide by 8 scaler, giving 1MHz operation.
Great... thanks a lot :slight_smile:
