A2dp library and SD
Im relativley new to arduino and im working on a new project which requires me to simply connect an esp32 to a pair of wireless earbuds. This is achieved by programing the esp32 as a an A2Dp source. The library im using has a built it in function which parses the .wav file and takes in 2 paramters, "fs::FS &fs" and the path which the .wav file is saved in:
bool parseWAV(fs::FS &fs, String path){
char chbuf[256];
audiofile=fs.open(path.c_str());
String afn = (String)audiofile.name(); //audioFileName
if(afn.endsWith(".wav")) {
    audiofile.readBytes(chbuf, 4); // read RIFF tag
    if ((chbuf[0] != 'R') || (chbuf[1] != 'I') || (chbuf[2] != 'F') || (chbuf[3] != 'F')){
        Serial.println("file has no RIFF tag");
        audiofile.seek(0);
        return false;
    audiofile.readBytes(chbuf, 4); // read chunkSize (datalen)
    uint32_t cs = (uint32_t)(chbuf[0] + (chbuf[1] <<8) + (chbuf[2] <<16) + (chbuf[3] <<24) - 8);
    audiofile.readBytes(chbuf, 4); /* read wav-format */ chbuf[5] = 0;
    if ((chbuf[0] != 'W') || (chbuf[1] != 'A') || (chbuf[2] != 'V') || (chbuf[3] != 'E')){
        Serial.println("format tag is not WAVE");
        audiofile.seek(0);
        return false;
    while(true){ // skip wave chunks, seek for fmt element
        if ((chbuf[0] == 'f') && (chbuf[1] == 'm') && (chbuf[2] == 't')){
            //if(audio_info) audio_info("format tag found");
    audiofile.readBytes(chbuf, 4); // fmt chunksize
    cs = (uint32_t) (chbuf[0] + (chbuf[1] <<8));
    if(cs>40) return false; //something is wrong
    uint8_t bts=cs-16; // bytes to skip if fmt chunk is >16
    audiofile.readBytes(chbuf, 16);
    uint16_t fc  = (uint16_t)(chbuf[0]  + (chbuf[1] <<8));  // Format code
    uint16_t nic = (uint16_t)(chbuf[2]  + (chbuf[3] <<8));  // Number of interleaved channels
    uint32_t sr  = (uint32_t)(chbuf[4]  + (chbuf[5] <<8) + (chbuf[6]  <<16) + (chbuf[7]  <<24)); // Smpling rate
    uint32_t dr  = (uint32_t)(chbuf[8]  + (chbuf[9] <<8) + (chbuf[10] <<16) + (chbuf[11] <<24)); // Data rate
    uint16_t dbs = (uint16_t)(chbuf[12] + (chbuf[13] <<8));  // Data block size
    uint16_t bps = (uint16_t)(chbuf[14] + (chbuf[15] <<8));  // Bits per sample
    Serial.printf("FormatCode=%u\n", fc);
    Serial.printf("Channel=%u\n", nic);
    Serial.printf("SampleRate=%u\n", sr);
    Serial.printf("DataRate=%u\n", dr);
    Serial.printf("DataBlockSize=%u\n", dbs);
    Serial.printf("BitsPerSample=%u\n", bps);
    if(fc != 1){
        Serial.println("format code is not 1 (PCM)");
        return false;
    if(nic != 1 && nic != 2){
        Serial.print("number of channels must be 1 or 2");
        return false;
    if(bps != 8 && bps !=16){
        Serial.println("bits per sample must be 8 or 16");
        return false;
    bitsPerSample=bps;
    channels = nic;
    sampleRate = sr;
    bitRate = nic * sr * bps;
    Serial.printf("BitRate=%u\n", bitRate);
    audiofile.readBytes(chbuf, bts); // skip to data
    uint32_t s = audiofile.position();
    //here can be extra info, seek for data;
    while(true){
        audiofile.seek(s);
        audiofile.readBytes(chbuf, 4); /* read header signature */
        if ((chbuf[0] == 'd') && (chbuf[1] == 'a') && (chbuf[2] == 't') && (chbuf[3] == 'a')) break;
        s++;
    cs = chbuf[0] + (chbuf[1] <<8) + (chbuf[2] <<16) + (chbuf[3] <<24) - 44;
    sprintf(chbuf, "DataLength=%u\n", cs);
    Serial.print(chbuf);
    posDataSection = audiofile.position();
    return true;
return false;
The problem is that i dont understand the first parameter of the funciton "fs::FS &fs". The example in the library uses the input "SD" in order to play the file from an SD card. I intend to play the wav file located in the same dir as the .ino file, so imnot sure what to replace the "SD" with.
What is the name of the library you are using? Is it a standard library with Arduino, or did you get it from Github?
