i've got a Uno, A4988 and a Nema 17 stepper motor. I can get the stepper motor working on it's own but i'm wanting to add switches to turn it x amount one way then the same the other.
now i can get the switch working and it will continiously turn the motor when pressed. Is there any suggestions on how i can get it to turn it x amount in either direction?
springs:
You need to view your program as two almost completely separate parts. One part reads a button and saves its value. The other part controls the motor based on the saved value.
Something like this pseudo code
readButton();
moveMotor();
void readButton() {
if (buttonState == HIGH) { // assumes LOW when pressed
// only read button if there is nothing happening
buttonState = digitalRead(buttonPin);
void moveMotor() {
if (buttonState == LOW) {
// code to move motor the required number of steps
buttonState = HIGH; // when motor is finished allow further reads of the button pin
